massive clear out off s body items from ca18,rb20 and sr20
parts located in hertfordshire , can post via my hermes ,ups or royal mail
s13 parts
1. drop resistor £20
2. alternator with bracket and adjuster £35
3. ptu £10
4. fan £15
5. Light weight fan pulley silver £10
6. Inlet bare £10
7. Rocker covers £25
8. Cas £15
9. Pas pot has a dent wrapped in silver £5
10. 180sx front subframe , £50
11. engine mounts £30
12. Fan shroud mint condition £25
13. auto rad £15
14. nd stage 1 chip £20
15. h dev stage 3 chip £45
s13 parts for free
1. Block needs hone from surface rust
2. Rods
3. Crank needs regrind
4. Engine brackets
5. Engine mount brackets
6. Dipstick
7. Old belts
8. Water pump
9. s13 bonnet peeling paint
random parts
1. ca18 X4 exhaust gaskets metal vgc £15
2. Inlet gasket to head used but good condition £5
3. Turbo to inlet pipe 3 hole £5
4. t28 braided water line long £15
5. Unknown Turbo timer with hks harness for s13 £20
6. apexi filter £30
rb20det parts
1. block needs hone takes oversized pistons 1.00 £100
2. x6 oversized pistons 79mm 1.00 need new rings £80
3. crank perfect conditon idea spare or replacement £150
4. oil pump near new £30
5. clutch fan £40
6. inlet bare £30
7. x6 stock injectors £80
8. fuel rail £20
9. Engine mounts
10. interior full loom £100
11. auto shifter with loom £50
12. inlet pipe and blank for dv £35
13. fuel tank pipe with fuel cap £45
14. auto flywheel ,tourqe convertor and dust shield £50
15. hicas pas pump £60
16. pas pot and bracket £10
17. cast manifold £30
sr20det
1. a/c pump 92600 52f03, 506031-0204 £80
s13 parts
3. ptu £10
4. fan £15
6. Inlet bare £10
8. Cas £15
13. auto rad £15
s13 parts for free
2. Rods
4. Engine brackets
6. Dipstick
7. Old belts
8. Water pump
random parts
6. apexi filter £30
rb20det parts
5. clutch fan £40
6. inlet bare £30
8. fuel rail £20
9. Engine mounts
sr20det
