May 26, 2018 20:00:58 GMT
I was thinking of building a Hot-Rod.
I'd like to try for a single donor.
What 1990-1998 V8 european (as in sold here) cars might be suitable?
May 26, 2018 20:10:26 GMT
In a Nutshell, Metrocab! Although it's not a V8 so you'll have to add that bit yourself! eBay item number: 182130333724
May 26, 2018 21:03:34 GMT
I’m guessing you need a chassis? Land Rover V8.... but that’s be pricey! No. I can make one if I have to. Well, tack one. The welding would be done by a pro.
What fits this criteria?johnthesparky
@johnthesparky
Club Retro Rides Member 6
May 26, 2018 21:21:38 GMT
Mate built a 27 T years back,
He used a front beam from a Sherpa Cortina axle Pinto and type 9 (but should have been a v8)
Chassis was a repro 32 with front horns, it wasn’t particularly complicated.... but you’d get into the IVA mess if not a body swap? Or is that not a problem?
If not chassis is easy to make, you’d just need some measurements and steel!
May 26, 2018 22:15:35 GMT
Mate built a 27 T years back, He used a front beam from a Sherpa Cortina axle Pinto and type 9 (but should have been a v8) Chassis was a repro 32 with front horns, it wasn’t particularly complicated.... but you’d get into the IVA mess if not a body swap? Or is that not a problem? If not chassis is easy to make, you’d just need some measurements and steel! See that's the thing. No test of any description for cars over 40. So if I used an old shell I could build anything. Some pretty radical rat rods over here now.
vulgalour
Club RR Member Number: 146
What fits this criteria?vulgalour
@vulgalour
Club Retro Rides Member 146
May 26, 2018 23:38:57 GMT
If you're not after an engine donor but are instead looking to build a hot rod 90s car, grab a Lexus LS400 before everyone pulls the engines out to put in other hot rods.
If you're not after an engine donor but are instead looking to build a hot rod 90s car, grab a Lexus LS400 before everyone pulls the engines out to put in other hot rods. Thats more like what I plan to do How hard/easy/expensive is that engine to get running in a new home?
I've done something wrong with the quote thing. This is what he said, See that's the thing.
No test of any description for cars over 40.Is this considered to be a good thing? I can see how this would give sensible people a little bit of freedom but there must be some absolute sh1tters still being driven by those who don't know or don't care how dangerously shagged their vehicles are. Nothing else to add other than to wish you luck with your project and please do remember to post a build thread.
Last Edit: May 27, 2018 9:34:55 GMT by igor
May 27, 2018 10:25:54 GMT
Mate built a 27 T years back, He used a front beam from a Sherpa Cortina axle Pinto and type 9 (but should have been a v8) Chassis was a repro 32 with front horns, it wasn’t particularly complicated.... but you’d get into the IVA mess if not a body swap? Or is that not a problem? If not chassis is easy to make, you’d just need some measurements and steel! See that's the thing. No test of any description for cars over 40. So if I used an old shell I could build anything. Some pretty radical rat rods over here now. Sorry I can't let that pass by. This would only be true if you used an original unaltered pre 1978 CHASSIS (not a body on a new chassis) original type engine and running gear that will fit without modification. So a VHRA style period hot rod could be built within the 8 points criteria, without the need for IVA with a genuine pre war base car, flathead, early Ford axles etc. Anything as described in your question, especially if you build your own chassis is definitely IVA territory. There are loads of threads on this here and the hot rod forums. This is a good one to start with
May 27, 2018 10:28:55 GMT
The OP is in Ireland, no idea if they have the same rules over there.
vulgalour
@vulgalour
May 27, 2018 12:31:54 GMT
You can't just use an LS400 for the engine and throw away the rest. All that potential, GONE. Make a hot rod LS400! Comfort and speedyzooms all in one.
May 27, 2018 13:01:56 GMT
See that's the thing. No test of any description for cars over 40. So if I used an old shell I could build anything. Some pretty radical rat rods over here now. Sorry I can't let that pass by. This would only be true if you used an original unaltered pre 1978 CHASSIS (not a body on a new chassis) original type engine and running gear that will fit without modification. So a VHRA style period hot rod could be built within the 8 points criteria, without the need for IVA with a genuine pre war base car, flathead, early Ford axles etc. Anything as described in your question, especially if you build your own chassis is definitely IVA territory. There are loads of threads on this here and the hot rod forums. This is a good one to start withNo test like that here in Ireland. I'msure the single car test will eventually arrive.
May 27, 2018 13:02:14 GMT
The OP is in Ireland, no idea if they have the same rules over there. Yup
May 27, 2018 13:04:17 GMT
You can't just use an LS400 for the engine and throw away the rest. All that potential, GONE. Make a hot rod LS400! Comfort and speedyzooms all in one. Well its one of a very few V8 cars that are availabe cheap. €600-1000 for a runner. And I was thinking more of Grenade-ing the thing.
May 27, 2018 16:22:10 GMT
The OP is in Ireland, no idea if they have the same rules over there. Apologies all round. I don't know the rules in Ireland. I'll shut up now.
Last Edit: May 27, 2018 16:22:24 GMT by ratchart
Porsche
West Midlands
Kev from B'ham.
May 27, 2018 17:03:39 GMT
Last Edit: May 27, 2018 17:04:48 GMT by Porsche
May 27, 2018 19:16:26 GMT
The OP is in Ireland, no idea if they have the same rules over there. Apologies all round. I don't know the rules in Ireland. I'll shut up now. No problem sir. Better to mention it and help out just in case.
May 27, 2018 19:17:35 GMT
Actually a Scimitar would be a great basis... And that looks good. Hmmm.
froggy
May 27, 2018 19:39:02 GMT
There are a few rods based on lotus 7 platforms that are worth a look . Same amount of work to graft a glass body onto as scimitar or other ladder type chassis but much more of a sports car to drive
