May 20, 2018 12:02:45 GMT
I have an electrical soldering iron but my garage is abit too far to run an extension lead to without someone tripping over it.
Does anyone have any experience with the gas or battery powered soldering irons?
1967 Beetle
May 20, 2018 12:30:48 GMT
Yes, don't bother.
May 20, 2018 12:47:24 GMT
Ditto the above, get an extension or do your soldering indoors.
May 20, 2018 19:26:32 GMT
I have always used gas with no problem but you get what you pay for, the tips do wear out after a while so its worth getting a good make so you can get spares, you may struggle on the heavier stuff but for general car work you shouldn't have a problem
May 20, 2018 19:35:20 GMT
I use a gas one all the time, never had a problem, just buy a decent quality one. I've had people come to me & say that their gas one is messing about, generally that's due to your can of gas running out & just having propellant left but no gas, if you turn it one & drain the gas, then buy a new can of gas & refill it it'll cure the problems.
May 20, 2018 20:01:19 GMT
I've had a snap on gas soldering iron for years now and it's been really handy It's probably the same as a 40w electric one so will depend on what your soldering
I try to use a 240v soldering iron whenever possible as they are better but that's a good option
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
ChrisT
Club RR Member Number: 225
Soldering IronsChrisT
@christ
Club Retro Rides Member 225
May 20, 2018 20:11:42 GMT
I'm not the worlds best solderer but I've had good results using a gas soldering iron from Maplins (although i think they're just closed down).....
May 20, 2018 20:42:41 GMT
Grandfather used to heat his soldering iron on a Primus stove.
May 20, 2018 21:10:54 GMT
I have a draper 12v one which is very good
- '88 MK2 Golf 1.3 c - '07 BMW E91 335d - '94 T4 1.9d
slater
Club RR Member Number: 78
Soldering Ironsslater
@slater
Club Retro Rides Member 78
Gas are fine mate. We use them at work as there's rarely a socket within easy distance.
May 21, 2018 11:17:49 GMT
I only need it for doing abit of light soldering to the wiring loom.
Any recommendations?
1967 Beetle
May 21, 2018 11:35:47 GMT
I'd get heatshrink solder joints, all you need is a small blowtorch or even a lighter.
sonus
May 26, 2018 18:04:24 GMT
My Dremel gas powered one works very well for my needs.
May 26, 2018 21:26:21 GMT
Always use gas. Got 3 different sizes of iroda solderpro ones, all work brilliantly
May 27, 2018 22:45:36 GMT
