BMW X5 4.4i automatic in Topaz Blue
2000 X reg = cheap road tax bracket (only £267.75 per year!)
Mot just run out on 3rd May (tax ran out 30th April)
I'm located in LS29, just north of Leeds/Bradford
Good points:
22 inch Antera alloys in good condition & great tread on all tyres
Great M62 TU B44 4.4i V8 engine & sounds awesome - 167k mileage, previous owner has done the timing chain & guides less than 5000 miles ago (I have the previous owner's receipt for the work)
I have also just put a new water pump on myself including new auxiliary belt, new valve cover gaskets both sides, new radiator, new thermostat and housing, new coolant crossover pipe o'rings at both ends, new spark plugs, new induction kit, secondary air pump delete & aircon delete (I also have receipts for all the parts I have fitted)
Rear black tinted windows, suspension airbags & electrics all work fine, beige leather interior is ok and not torn or ripped, manuals & a little history, logbook present
Bad Points:
Reverse is not working, just revs (drives forward fine - second hand gearbox on Ebay right now for £185)
Rear door handles don't work from the outside (needs new carriers which are £17.99)
No radio unit & rear boot shelf missing
Battery went flat as I hadn't driven it for a while so ABS/DSC light now needs switching off (common issue when the battery gets low)
£1200 or £900 without the wheels - no offers at this price please
Good points:
Bad Points:
