Micro dynamics swift shift, this one box of tricks does it all;
- Rev limiter
- Shift up/down lights
- Flat change / launch control - basically a second Rev limiter cut in by grounding a wire either through a clutch pedal switch (flat change) or a push to make switch (launch control)
All rpm fully configurable.
Same as this;
www.demon-tweeks.co.uk/performance/shift-lights-rev-limiters/micro-dynamics-swift-shift
£60+p&p or can bring to RR Weekender.
Used in a race car for a bit but in great condition.
- Rev limiter
Same as this;
