I have a lot of baked on thick diesel on a engine in difficult places to clean and need to get it off to pull the injectors . A mechanic i spoke to today said that there is a specific product available to do this which came a s a surprise to me .
Does anyone know of such a thing actually exists as i either cannot find it or cannot think of the right search terms to find such a thing . Have used oven cleaner so far but if there is something better that would be good to know.
93fxdl
Enter your message here...
Oven cleaner does the job Ttfn Glenn
mgmrw
Halfrauds sell "gunk" by Jizer.tin of it about a fiver.
Brush on, leave, agitate, rinse off.
I used it extensively on a 71 minor. Years of caked up engine.
May 10, 2018 11:39:53 GMT
Pressure washer is usually enough.
May 10, 2018 11:47:20 GMT
Gunk works.
May 10, 2018 19:06:30 GMT
Can you get the nozzle of a steam cleaner in? Its usually virtually turned to carbon, hence oven cleaner working.
May 10, 2018 20:31:30 GMT
Nah , if the engines cold its like rock hard anthracite or coal . If the engine is warm its like toffee . Down in the valley around the injectors [ which have to come out ]
Had some success with oven cleaner and a large syringe with tubing but was looking for something faster . White spirit was ok as well might try that and leave it for a few hours .
May 10, 2018 21:53:07 GMT
Mercedes CDi? Renault dCi? Vauxhall CDTi?
Those seem to be the worst candidates for leaky injectors with the horrible black wibblepoo they spew!
May 11, 2018 16:39:03 GMT
Mercedes CDi? Renault dCi? Vauxhall CDTi? Those seem to be the worst candidates for leaky injectors with the horrible black wibblepoo they spew! Saab tid ! Its horrific ! Bosch injectors !
mgmrw
May 11, 2018 20:37:21 GMT
Mercedes CDi? Renault dCi? Vauxhall CDTi? Those seem to be the worst candidates for leaky injectors with the horrible black wibblepoo they spew! Saab tid ! Its horrific ! Bosch injectors ! 9-3?
May 12, 2018 23:43:00 GMT
Mercedes CDi? Renault dCi? Vauxhall CDTi? Those seem to be the worst candidates for leaky injectors with the horrible black wibblepoo they spew! Saab tid ! Its horrific ! Bosch injectors ! Ah yes, the Vauxhall 1.9. Famous for it. Are you replacing injectors? We had a batch of wibblepoo diesel a couple of years ago and it wiped out a full set of injectors on a mates car, one at a time. Painful to change.
Saab tid ! Its horrific ! Bosch injectors ! Ah yes, the Vauxhall 1.9. Famous for it. Are you replacing injectors? We had a batch of wibblepoo diesel a couple of years ago and it wiped out a full set of injectors on a mates car, one at a time. Painful to change. No just the seals . The previous owner , a work colleague had them done 30k or so ago but to are blowing out from the bottom . Think its any car that uses this particular bosch injector . Not a great fan of this engine apart form it going quickly when it works .
May 24, 2018 14:01:15 GMT
You can do that with petrol at 1/8th of the price!
May 30, 2018 17:55:25 GMT
if a paint brush can be used to agitate the area then I would also use petrol too
