Willwood front brake setup.
New, but have been bolted to uprights for mockup only (no longer have uprights).
There's a pair of new 4 piston radial calipers complete with spacers & mounting brackets.
New, boxed Wilwood pads.
New discs - 285mm diameter, vented, drilled & grooved - detailed info in pics - have picked up light surface marking from previous storage.
Hubs - used, but good condition (5 × 4.5" PCD), with inner & outer bearings, studs, nuts (nuts a bit rusty).
Will bolt straight to Ford struts.
Should fit other suspension setups as mounting brackets are bolted to calipers with spacers.
£675 ono
PM me for more info etc.
£675 ono
