Look, the suns is out, you need a convertible, one that creamed the mot on 17/04/18 with no advisories and only 74300 miles. MILEAGE CORRECTED
Since I became the owner I have put on/in :
Windscreen
Washer pump
Braided hoses
Exhaust rubber
Springpan poly bushes
Fusebox
K&N in stock airbox
Blower resistor
Tool roll
Fusebox cover, staggeringly with an unbroken one
Correct size wheels and tyres, tyres of a make you have heard of
Various bits of trim/fasteners
Couple of weeks ago she had all 8 spark plugs, factory ones.
4 good used coil packs
Bosch lambda sensor
Thermostat and fresh coolant.
Oil and filter
I have removed the aircon compressor as the system did not work, along with mounting gubbins, it is after all a convertible and has windows that open, I fitted a shorter aux belt, this allows the engine to access all its 150bhp without driving the aircon pump.
I have removed the balance belt which aides the way it drives.
Now it is a 20 year old Italian convertible, it’s not new, unhappy on rough surfaces but copes with a bit of shaking, get smooth tarmac and it’s fabulous.
Electric roof works
Doors don’t crack
It’s just time for a change
Price is fair, some have them up for 4K+ and they are not twice as good as mine
Spare alloys, headlights and bits I can find will be included
Swaps and p/ex of course will be considered
£1800
Windscreen
Washer pump
Braided hoses
Exhaust rubber
Fusebox
K&N in stock airbox
Blower resistor
Tool roll
Bosch lambda sensor
Oil and filter
Electric roof works
Doors don’t crack
£1800
