I have just been fitting my bias box to my little austin, Discs on the front, calipers using no more volume than a Lockheed M16 rears are stock anglia drums, so, in reality the braking system uses no more fluid capacity than a Mk1 Mexico, or similar.
My bias box uses 0.70 and 0.626 cylinders, my locic says put the smaller cylinder to use with the front brakes and the larger to the rear, then adjust the bias to get a decent feel, I know using the smaller cylinder this way will give me a longer pedal but better feel, reading else where there seems to be a bit of a split of thoughts in which way to plumb the system and what cylinder sizes to use..... thoughts anybody?
