Smiler
Hi folks,
I'm loking for a replacement radiator for my Scimitar project. I have re-engineered the front end support structure and want to fit the biggest radiator I can squeeze in there.
Does anyone know of any online catalogues or lists that give details of radaitor dimmensions, pipe orientations and which vehicle they are from?
Regards,
Smiler.
steveg
Smiler
Thanks, that's a pretty good start.
nassas
May 30, 2018 15:04:15 GMT
Wakefield car radiators with over 90 years experience Phone: 01924 383155
May 31, 2018 22:42:12 GMT
There is a company called Nissen that make replacement radiators for most cars. Years ago I had them send me a list with all their dimensions. I don't have the list anymore but give them a try.
tristanh
Routinely bewildered
Somora is another one, I use both the catalogue and the actual rads.
Smiler
Jun 13, 2018 21:34:39 GMT
Cheers folks, much appreciated. I have just about finalised the SCimitars ne nose support frame so I now have the final available dimensions fixed for sizing the bigest rad I can squeeze in there (710mm wide by 410mm tall). Cheers, Smiler.
froggy
Jun 14, 2018 19:23:44 GMT
Euro car parts usually have a Nissens catalogue in there branches , I borrow it if I need to find something suitable
rollingcoal
we can engineer a way around that, maybe
Jun 16, 2018 11:51:15 GMT
A55 Austin Cambridge 1961 Triumph Spartan 1965 mk1 Ford Escort 2 door 1968 Peugeot 406 diesel estate 1998 Citroen Xsara hatchback diesel 1999
Smiler
Jun 16, 2018 16:32:04 GMT
Wow, that's pretty close! Pipe orientation is opposite to ideal but it's certainly a contender.
