Mar 25, 2018 14:06:27 GMT
So I did have a 2nd track car already which was a Clio 172 Cup but I'm a JDM fan at heart. A friend of mine had an EF lying around he wasn't using that was built by a company that another mate of mine owns. So the Clio Sold at the weekend and I was offered the EF. After having two CRX previously, one of which had a B18 swap and various other Hondas. Anyway always fancied an EFand having the B18 already makes it perfect to turn this into a track car.
This Race car build is Sponsored by Jamtech Motorsport, Avon Tyres, Caged Laser Engineering, Infinity Exhausts, Sprinting Hare JDM, Rose Race Cars, VDM Motorsport, Harvey Motorsport, Track Car Door Cards, AJU Motorsport, 6Two1 Auto Supply and Reelmotion.
Current spec:
- Engine MB6 B18C4
- Brian Crower Stage 2 Cams
- Adjustable Vernier Pulleys
- Titanium Valve spring & Retainers
- 440cc Injectors
- AEM Fuel Rail
- AEM FPR
- Baffled Sump
- Blocks Inlet Manifold
- Larger iTB
- Infinity Exhausts 2.5" Stainless Exhaust System
- P28 Chipped ECU 4.2k VTEC 8.8k rev limit
- VDM Motorsport Wiring Harness
- S9B LSD Gearbox
- Lightweight Flywheel
- Team dynamics 1.2’s
- AVON ZZR 205/50/15 Semi Slicks
- Tegiwa Alloy Radiator
- BC Racing RH Coilovers Custom Spring Rates
- Uprated Front ARB EK VTi/DC2
- CRX VT Front Hubs
- Hardrace Rear Camber Arms
- VTi Spoiler
- Fibreglass bonnet
- Fibreglass wings
- J's Racing front lip
- ACW Motorsport Poly Windows front
- BYC Sunroof Bung
- Ally fuel tank
- Braided fuel lines
- Uprated fuel pump
- MB6 Hubswap Rear 262mm
- MB6 Hubswap Front 282mm
- Hel 666 Front Pads
- MTEC Front Discs
- Hel Full Braid line Kit
- Hel Brake Bias Valve
- Fully polybushed
- MB6 Rear Trailing arms
- Hydraulic clutch conversion
- Hardrace LCA's
- Hardrace Front Camber Arms
- PAS delete
- Motordrive Carbon Kevlar Seat
- Jamtech Motorsport custom seat rails
- TRS Harness
- AEM AFR Gauge
- SPA Oil Pressure Gauge
- EK VTi Clocks
- Type R GearKnob
- Caged Laser 6 Point Bolt in MSA Caged Engineering Roll Cage
- SPA MSA extinguisher kit
- MSA Rain Light
Mar 25, 2018 14:16:13 GMT
b3nson
Club RR Member Number: 22
Mar 25, 2018 16:28:49 GMT
Very cool! Bet a B18 is great fun in that. Love the chunky wheel/tyre fitment too
'99 Fiat Coupe 20V Turbo '08 Panda 100HP
So been ordering goodies over the past week and they have started to arrive. Also popped to local custom exhaust company near Bristol Infinity-Exhausts. They made me up a bespoke 2.5" system that's stainless and track friendly. I now plan on racing this car in the local Hatch series in 2019 so this is now a race car build thread . The old system was a bodge of stainless and normal steel and was truly terrible as you can see. I need to run 100DB's at 4500rpm so a 10"x5" single silencer was made. On this car I wont be running the fuel tank on the underside which means on the EF I can run the system straight down the car improving flow. We also went for a large 2.5" bore. B series engine respond really well to breathing mods. The end result a reasonably light, durable system that improves performance.
I like this!
My friend has an EH and happened to be at infinity last weekend for a new system. He’s running the trusty D series though.
You guys run those farm track events in Wales don’t you? A friend of mine has shown me some videos and is planning to get to one when his EK9 is back together.
Hi mate yea one of the staff showed me a pic of that very car lol. I only live 15minsfromthere anyway close to Castle Combe. Yes we run Touge in The Valleys events. its pretty cool. 2.2miles of tarmac stage in Mid Wales.
79cord
Look forward to seeing the progress. Should sound potent. Doesn't help my urge to give my ED DOHC, or a bigger exhaust for DC2, when I should be getting them on the road!
2.5" on a petrol 1600 is a bit overkill unless you're knocking on 250 bhp...
2.5" on a petrol 1600 is a bit overkill unless you're knocking on 250 bhp... I'm afraid that's not true mate. I have worked for a custom exhaust company in the past and also a dyno. and I can tell you first hand especially on NA Hondas a larger bore of at least 2.5" will increase your power by 10-15bhp with a standard B series or K series engine. Many of the Honda guys even run 3" if they can fit it under the car.
79cord
So will a normal bonnet fit over the B18 or require the Vtec bonnet.?.. or will you go for custom Vtec to close the gaps around smaller std headlights? That DOHC D16 bonnet looks a little wobbly, but a suppose is a common problem for plastic panels with heat. I still want to make a custom clamshell inc. fenders for my CRX project... one day..
Last Edit: Apr 3, 2018 23:31:09 GMT by 79cord
j4mes
2.5" on a petrol 1600 is a bit overkill unless you're knocking on 250 bhp... I'm afraid that's not true mate. I have worked for a custom exhaust company in the past and also a dyno. and I can tell you first hand especially on NA Hondas a larger bore of at least 2.5" will increase your power by 10-15bhp with a standard B series or K series engine. Many of the Honda guys even run 3" if they can fit it under the car. I'm running 2.5" on my H22a7, but 3" is supposed to be worthwhile doing, but can effect what little low-down power it has. Vtec engines react very well to proper intake/exhaust mods.. Ps bookmarked, keep up the good work!😁
So will a normal bonnet fit over the B18 or require the Vtec bonnet.?.. or will you go for custom Vtec to close the gaps around smaller std headlights? That DOHC D16 bonnet looks a little wobbly, but a suppose is a common problem for plastic panels with heat. I still want to make a custom clamshell inc. fenders for my CRX project... one day.. Yea the standard bonnet bend over the B18 and currently touches so gone for a VTEC bonnet but with a 16v bulge in fibreglass, I can space it if needs be and will be fitted with bonnet pins.
Davey
Resident Tyre Nerd.
This looks great very Kanjo looking!
K11 Micra x3 - Mk3 astra - Seat Marbella - Mk6 Escort estate - B5 Passat - Alfa 156 estate - E36 compact Mk2 MR2 T-bar - E46 328i - Skoda Superb - Fiat seicento - 6n2 Polo - 6n polo 1.6 - Mk1 GS300 EU8 civic type S - MG ZT cdti - R56 MINI Cooper S - Audi A3 8p - Jaguar XF (X250) - FN2 Civic Type R - Mk2 2.0i Ford Focus - Mercedes W212 E250
This looks great very Kanjo looking! How often is your list of cars longer than your post lol that's awesome
Davey
Resident Tyre Nerd.
This looks great very Kanjo looking! How often is your list of cars longer than your post lol that's awesome I get bored easily! Really love me an older civic i totally missed the graphic designs even more Kanjo looking! More of this!
No doubt you will see an increase if you go from 1.5 to 2.5, but 2 or 2.25 would be beneficial and give you some real world torque.
even WRC cars shifting enough air for 360 bhp just run 3"
my 240 bhp engine runs a 2.25 and 190 LBFT.
No doubt you will see an increase if you go from 1.5 to 2.5, but 2 or 2.25 would be beneficial and give you some real world torque. even WRC cars shifting enough air for 360 bhp just run 3" my 240 bhp engine runs a 2.25 and 190 LBFT. Sorry mate but I have seen first hand over quite a few years in different jobs that the size I have chosen works. I don't need to be told by someone else. 2" would strangle the B18 engine.
brief update spent a day stripping some more weight out the car. The sunroof was at least 20KG. Also stripped the front end ready for Fibreglass panels. Also picked up some pretty cool Carbon Kevlar seats for just £300
