Hi folks,
I've got a complete rear axle from a volvo 760.
It's IRS, so an upgrade compared to the beam axles on the estates (and maybe some saloons?). Ideal for someone wanting a strong diff in a kit/modified car but something a bit better than a beam axle. Should be easy enough to mount on a chassis or whatever you're looking to build it on
It's a bit crusty, but pretty much everything ought to clean up well, although the brake backing plates are a bit knackered.
Comes complete with brakes (rear discs, with drum in disc handbrake). If anyone wants it to fit to a 740/940 it's got the plates that bolt straight into the body instead of the beam rear axle, and I've got the IRS fuel tank which wraps around it and is larger too.
Looking for £150 ONO - it's in Bristol but I travel a bit for work so could potentially arrange delivery to some parts of the UK
