smith4
[/quote]I take my hat off to you, its not easy working in the limited space that you have! It looks like I have a smidgen more than you and it gets so frustrating tripping over things, but keep up the good work it'l be worth it in the end.[/quote]
Thanks Paul!
I do tread on things a little, and lose things when I've put them down right next to me and haven't moved (!), but it is bigger than a standard garage, so I am lucky.
It's ssurprising just how much space a little car takes up when it's not in one piece.
I'm so looking forward to it being back on 4 wheels again, and am hoping to get the V8 in this year!
Good work on your Manta. Shame about the splitter getting hit again. Great work on the inlet manifold/injection system - wild paint job!
louisw
Jan 21, 2020 19:59:38 GMT
This build is fantastic, and i'm glad one of my photos was useful from my build thread of my MKIV. [/quote] Hi Louisw, Thanks for this, your photo came in really handy! I didn't have one myself that clean and that angle. Do you still have your Spitfire? [/quote] Glad it was of some help! I do still have my spitfire but not touched it in years as its not at my house at the moment. Hoping to get it up again and continue the project! Would be stripping it down completely and moving away from OEM I think.
smith4
Small upadate - I finally got an inlet manifold! I was impatiant with waiting/looking, but miraculously this one came with the thermostadt housing, other water pipey thingy, and also what looks like a pertinax plate! I used some cleaning petrol to get it this clean, but needs ideally could be cleaner! The GT6 is now up on ramps/axles stands as I'm hoping to get the driver's side sill all finished this February. Bulkhead is finally almost down to bare-metal, and scuttle/top of bulkhead rubbed down a little to maake it smoother before some coats or primer. Tried the 8.5" rear wheel on the front - looks well wide! Need to re-paint the rims now they're back from being narrowed.
smith4
Mar 18, 2020 16:18:55 GMT
smith4
Mar 18, 2020 16:29:50 GMT
I also am further on with the driver's door. I hadn't realised just how many dents/little dings it had! It will be no-where perfect once done, but as long as it looks straight and I can get the panel gaps good, that should be fine 🙂 So, door and panel gaps to work some more on! And also, it's so great to have the door brace gone! I can technically sit in the driver's side again! Can't wait to get it back safely on all four wheels! Rear wheels will need a 3mm or 5mm spacer to get right close to the arches. This pic as is: These photos with a very rough 5mm spacer. I'll need to get the tyres on first though before I know what spacer size to get. Just need to finish the wheels and get them into paint then find a tyre fitter that can get the tyres back on 🙂🙂
Last Edit: Mar 18, 2020 16:32:20 GMT by smith4
Mar 18, 2020 19:45:25 GMT
My new desktop fankooverymuch.
smith4
Mar 18, 2020 20:10:34 GMT
[/quote]
Mate, thank-you 🙂
smith4
Mar 19, 2020 22:37:39 GMT
Quick front end shot from today ...
smith4
Apr 11, 2020 17:27:48 GMT
So, the Offenhauser manifold is now on! Test fitment to check stuffs. It will get a new valley gasket!! And then a drop-base air filter base from America. This puts the bottom of the air filter 2" below the top of the carb. You can see my 2" element isn't therefore tall enough, so the air filter lid rests on the carb top. But with a 3" element, that shuld be fine.
smith4
Apr 11, 2020 17:32:28 GMT
The manifold ideally needs a bit of height milled off (as per mentioned earlier in this thread (thanks Darkspeed)), so hopefully will allow me to get the whole V8 amd carb/filter under the bonnet without mods 😃 I've also been battling with panel gaps and more filler work!
smith4
Apr 11, 2020 17:36:17 GMT
Apr 11, 2020 21:03:37 GMT
I feel dirty liking this.
But I do.
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
smith4
Apr 18, 2020 14:10:29 GMT
I feel dirty liking this. But I do. My nostrils feel dirty each time I exit the garage - filler dust needs removing! But more filler dust to come !!
smith4
Apr 18, 2020 14:15:15 GMT
smith4
May 24, 2020 11:45:33 GMT
Been a while, I hope everyone is keeping well in the current situation! I finally got my rear wheels finished (?!) and into paint. A tyre place just round the corner from the end of my road was miraculously able to mount the tyres too, which I really appreciated! The stretch is good, and 175 50s work well on the 8.5" wide. Then, I treated myself and got the car onto all fours for the first time since November 2019! I had added my second batch of camber spacers on the front, but it's definTely too much, so they'll be coming off again. Fun for a laff, but won't be good for daily use. Note to small chassis Triumph peeps. - If you are adding lots of front wishbone camber shims/spacers, as the lower wishbone is pushed further out, the car gets lower due to bottom mount of the shock absorber being mounted to the lower wishbone. I found this out (again) when lowering the GT6 down off the jacks and the sill/chassis got stuck on the floor! So I raised it a little after that! Grounded! Raised a bit and pushed outside! So good to have it back down again 😃😃
fogey
May 24, 2020 12:33:29 GMT
Nice project. Would look so much better just lowered without the stupid camber. Just my humble opinion, obviously.
1967 Triumph GT6 (Smith4)johnthesparky
@johnthesparky
Club Retro Rides Member 6
May 24, 2020 15:10:32 GMT
I personally wouldn’t run that camber either..... But I’d stop and look at it as it drove past, and if I saw it at a show I’d stare for a long time.... and both of those scenarios would make me smile so thanks for building it, and hopefully I’ll get to stare at it one day
May 24, 2020 16:51:53 GMT
Saw this on instagram yesterday, what an awesome car. Love it
Insta: lewdeak1986 E28 518I 50% of a MK1 Golf 2003 Lupo GTI
Porsche
West Midlands
Kev from B'ham.
I think it too would be better without so much camber, but I suspose that without it you wouldn't get those wheels under the arches as they are and the whole look would be ruined if you added arch extensions.
I think that it just doesn't look like it would be nice to drive, but we aren't driving it, you are. So good on you.
May 25, 2020 12:18:26 GMT
My only thought is...how many miles before the first tug?!!!
