sebb
A while back i noticed after parking my car up for the night (from memory it may have been under a tree :/ tree sap??) that there were tiny specs all over my windscreen. I tried to remove these using windscreen cleaner to no avail, i also tried a claybar, helped a bit but there is still so much present. Is there anyway of removing this?
thanks for any help
Last Edit: Feb 26, 2018 10:00:48 GMT by sebb
Feb 26, 2018 10:12:34 GMT
They might be road tar - try a solvent - something like lighter-fluid, Acetone or white spirit on a soft cloth and see if it loosens/melts the marks
Feb 26, 2018 10:32:53 GMT
a razor blade is one trick I've seen and used, you have to be careful not to dig the corners in.
sebb
Feb 26, 2018 16:25:55 GMT
Ok thanks, I'll give them a try, it's not so bad until there's a bit of sunlight and it makes it very difficult to see
Feb 26, 2018 17:49:15 GMT
If all else fails someone like Frosts do a glass polishing kit, not sure how good it is, but I bet its not cheap. Supposed to get rid of scratches, so mildly abrasive, might do the trick?
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
They might be road tar - try a solvent - something like lighter-fluid, Acetone or white spirit on a soft cloth and see if it loosens/melts the marks Don't spill the acetone! It will remove the paint and the wiper rubber!!
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
fulvia1436
They might be road tar - try a solvent - something like lighter-fluid, Acetone or white spirit on a soft cloth and see if it loosens/melts the marks Don't spill the acetone! It will remove the paint and the wiper rubber!! Old windscreens are a PITA when the sun's out! Mine's irreplaceable except with a modern version, which has fewer profiles and is less attractive. And £225
Feb 27, 2018 10:07:02 GMT
I was about to say, you can polish it but be careful. I usually just live with it, easy to crack.
sebb
Feb 27, 2018 15:20:07 GMT
That's the thing it's not actually that old a windscreen, it's on my daily which is a 52 plate passat, however it was replaced not that long ago, the specs on it appeared over night :s yer ill give some of these a try when the weather warms up a bit , thank you
Last Edit: Feb 27, 2018 15:20:36 GMT by sebb
fulvia1436
Feb 27, 2018 19:15:01 GMT
That's the thing it's not actually that old a windscreen, it's on my daily which is a 52 plate passat, however it was replaced not that long ago, the specs on it appeared over night :s yer ill give some of these a try when the weather warms up a bit , thank you Has the car been in a garage recently, where some grinding might have taken place? Glass melts under a shower of molten steel swarf.
Feb 27, 2018 21:38:48 GMT
Ive heard of people polishing with wire wool.
fulvia1436
Feb 27, 2018 22:07:40 GMT
Ive heard of people polishing with wire wool. Yeah, I bought some of the ultra fine wire wool, but haven't dared try it yet. They talked of applying some kind of Rainex stuff, after, which rather unconvinced me. I'd like to hear from anyone that's tried this method.
Last Edit: Feb 27, 2018 22:08:16 GMT by fulvia1436
sebb
That's the thing it's not actually that old a windscreen, it's on my daily which is a 52 plate passat, however it was replaced not that long ago, the specs on it appeared over night :s yer ill give some of these a try when the weather warms up a bit , thank you Has the car been in a garage recently, where some grinding might have taken place? Glass melts under a shower of molten steel swarf. No, it was literally parked up for a night and the next day I noticed it, like I said i'm not if it's tree sap or if someone has sprayed something over?
A while back i noticed after parking my car up for the night (from memory it may have been under a tree :/ tree sap??) that there were tiny specs all over my windscreen. I tried to remove these using windscreen cleaner to no avail, i also tried a claybar, helped a bit but there is still so much present. Is there anyway of removing this? thanks for any help Toffee Wheel! works a treat
VW nut 1984 MK2 golf type 19e
