Sept 15, 2018 19:55:55 GMT
Er - The above question appears to be answered without me even moving my lips - just like magic Started to flat back the lacquer - wet 1500's Followed by 2000's again wet - I would not recommend tackling the entire panel in one go - just a section at a time say 400mm x 400mm - be careful when flatting for polishing that you don't rub through especially on raised swages / panel edges etc So here comes the first stage polish - a medium compound Always use the mop to spread the compound / polish to the panel - start the machine without doing this and the compound will spatter everywhere Again work small sections of larger panels on a methodical basis It will not take long to gain the required results One hour later Compounds contain polymer fillers - I always wash these out of the panel with a little soapy water if I am following with further polishing stages The polishing process can be messy and I would recommend leaving the car masked up to prevent the polish contaminating the rest of the vehicle has it is very difficult to remove once dried and can leave a vehicle looking dreadful Stage 2 which is a fine compound Again washed with a little soapy water to remove the compound fillers Stage 3 which is a polymer polish Nearly there - a few very minor areas that I will go back over now - once I have the car completed it will have a polymer protection coating applied to it Flatting & polishing should remove all minor dust nibs and give a high quality finish to the panel - of course this can only be achieved if the preparation & paint application is undertaken correctly in the first place
Last Edit: Sept 15, 2018 19:56:44 GMT by Deleted
Sept 15, 2018 20:24:05 GMT
Wet flatting, I read a tip about putting a tiny drop of fairy liquid in the water to act as lubricant/ anti surfactant. Is this a grave Error?
Sept 15, 2018 20:56:28 GMT
Wet flatting, I read a tip about putting a tiny drop of fairy liquid in the water to act as lubricant/ anti surfactant. Is this a grave Error? Darren - Not at all - very useful tip - I use a bar of hand soap - has you state it acts has a lubricant - this in turn prevents the wet & dry dragging, clogging or digging in and creating more work
Sept 15, 2018 21:25:10 GMT
Wet flatting, I read a tip about putting a tiny drop of fairy liquid in the water to act as lubricant/ anti surfactant. Is this a grave Error? Darren - Not at all - very useful tip - I use a bar of hand soap - has you state it acts has a lubricant - this in turn prevents the wet & dry dragging, clogging or digging in and creating more work Imperial leather, right?
Sept 15, 2018 23:20:23 GMT
Hands that do dishes Darren.
Sept 16, 2018 20:03:18 GMT
Flatted and polished the wings Sorted & cleaned up the bumper vents / grilles etc - gave the mesh a good clean and repainted in satin black - the silver gill vents were also repainted Fitted the bumper back up once the vents / grilles were dry - most trims & lamps are fitted from the rear on the vast majority of modern plastic bumpers Part fitted to the car - I will complete it in the morning I still have to flat & polish the bumper but I prefer to do this on the car - the large nose type bumpers are very flimsy and easy to damage when off the car and only become structurally workable when fastened to the car There was some light corrosion around the bonnet striker plate caused the reaction of dissimilar metals - all alloy bonnet and the steel / plated striker plate - this was attended to & repainted
Last Edit: Sept 16, 2018 20:06:44 GMT by Deleted
Sept 16, 2018 20:12:20 GMT
Great work as usual, The quality and finish would put most professional bodyshops to shame, or hopefully shame them in to doing better work!
Sept 17, 2018 19:39:34 GMT
Bumper flatted prior to polish Polished, wheelarch liners refitted, bumper harness connected, headlamps refitted & lenses polished Nearly there then - final polish & valet tomorrow - refit the front wheels - check the lights and then I can deliver it back
Sept 18, 2018 19:11:00 GMT
I should have had this finished today - however I did a lights check & all was ok - then checked the headlamp washers which were both operative - however the washer bottle then continued to syphon it's self dry So back off with the bumper to find out what's going on - which in turn requires removal of the headlamps - the connectors to the washers are a odd clip type system and the one on the offside had managed to eat it's seal - soon sorted with a new o ring and then refitted the bumper - only then to find on the floor a puddle of coolant - the car has rads either side of the bumpers which are then plumbed to the rear of the car - there is a plethora of pipes at the front of the car and upon inspection I had slightly disturbed someone's previous bodge on a small balancing / breather pipe The broken end of this male fitting had been bodged with sealer to effect a repair - not quite sure what the bodger was thinking - it could have quite easily failed dumped the coolant and cooked the engine and cant imagine any change out £10k for a engine rebuild on one of these I disconnected the pipe and rang Reading Porsche fully expecting the part to be stupid money but no its a tad over £20 delivered and will be with me in the morning So close yet so far My hate of bodgers has just increased to a unheard of level !!
Last Edit: Sept 18, 2018 19:11:37 GMT by Deleted
Sept 18, 2018 19:53:03 GMT
Probably a blessing in disguise that leaky washer. If that fitting had let go anytime in the next six months you’d have copped the blame.
Sept 18, 2018 19:59:46 GMT
At least it had not fallen off a ramp!
Sept 18, 2018 20:12:31 GMT
Probably a blessing in disguise that leaky washer. If that fitting had let go anytime in the next six months you’d have copped the blame. Glen - very true but I also hand over a decent sum of money each year in exchange for something called a Motor Trade Policy which covers all vehicles in my care, the P38 & car trailer, public liability and importantly product liability which means I can put a guarantee on my work and cover such events should they ever occur - (comes at price though and I am still smarting from just paying the premium for the next 12 months)
Sept 21, 2018 19:32:45 GMT
Sept 21, 2018 19:35:40 GMT
Scooter side panel straightened up and profiled Polyester primed & guide coated Painted & polished
Sept 22, 2018 10:05:11 GMT
Theres an Australian guy on youtube called restolad(?) who did a tutorial fillerless repair on vespa side panel with slappers, dollies and body files. It's mesmerising but had opposite effect on me.
Sept 22, 2018 12:42:00 GMT
So the radiator pipe turned up promptly the next morning - now fitted & tested Is Flatcap your "street moniker"??
Sept 22, 2018 19:29:39 GMT
So the radiator pipe turned up promptly the next morning - now fitted & tested Is Flatcap your "street moniker"?? Nope - everyone either knows me has Grumpy or Chris - However the trading title of my business is slightly creative - I was born in Yorkshire, hence I have a Yorkshire accent - By & large there is always a Jowett in the workshop of some type or model which were all built in Yorkshire - I like to be creative in everything I do so when thinking about a name for the business I thought about my background, where I was born & what I worked upon and what linked me to my home county - whilst looking at a period production line picture of the Jowett factory all the men were wearing flat caps - Has an aside I have worn a flat cap for the last 15 years and when I linked this - 'Flat Cap Classic Cars' was born
Sept 25, 2018 9:16:49 GMT
1978 Saab 99 Turbo bonnet that has been hanging around the workshop for months awaiting paint Going to have to bare metal it though - it has lots of blisters to the paint surface and has had a few coats of paint in it's life A few coats of a strong paint stripper later Sanded back with 80's on the DA Deep rust pits to the front edge attacked with the rotary wire brush and treated with Hydrate 80 overnight
Last Edit: Sept 25, 2018 9:19:04 GMT by Deleted
samta22
Stuck in once more...
Club RR Member Number: 32
Sept 25, 2018 10:57:31 GMT
Chris, I suspect you have mentioned elsewhere but what stripper do you use?
Sept 25, 2018 22:12:16 GMT
Chris, I suspect you have mentioned elsewhere but what stripper do you use? Sam - This stuff - should be readily available but let me know if not I will locate a trade stockist for you
Last Edit: Sept 25, 2018 22:13:30 GMT by Deleted
