I'm having to buy a Zafira automatic with an apparently knocking bottom end. I'm buying it because i supplied the engine.. It is 20 miles from me. It does run but (i guess) could stop at any point. It's also easier for me to flat tow it with an a-frame It's around a 2004 model. Straight forward auto. Not semi automatic or anything I want to sell it off in parts so don't want to knacker the gearbox It won't be on a motorway but maybe National speed limit roads Should i do it? Any tips or tricks? Removing the driveshafts before i set off isn't really an option
I'm no mechanic but have always thought you cant tow an automatic and recently I needed to get an automatic non runner to a mechanic and he said your fine to tow it in neutral as long as you don't go over 15mph so i'm pretty sure you really cant do it without a trailer.
Yeh annoyingly there are different takes on it but a lot do say go slowly <25mph for a limited mileage
At the moment my plan is to leave the engine running which for as long as it lasts should lubricate the gearbox
mk2cossie
Club RR Member Number: 77
Is it actually an automatic with torque converter or one of those fangled automated manual boxes? If it is manual based, they usually have a bit to wind in/out near the selector to engage neutral
Where is it, and where do you want it taken to? Try the Pony express section?
Where is it, and where do you want it taken to? Try the Pony express section? Thanks, i decided to buy it as an engine i sold them suddenly started rattling and banging after they fitted it. I could have refunded the engine and be out of pocket but instead i have paid over the odds for the whole car which hopefully will claw back some profit in parts over the next few months. So, because i didn't want to buy it in the first place, i didn't want to spend any more money picking it up Is it actually an automatic with torque converter or one of those fangled automated manual boxes? If it is manual based, they usually have a bit to wind in/out near the selector to engage neutral It's the really simple old fashioned type with a torque converter I went to get the car today. Unfortunately the engine wouldn't idle so i couldn't leave it on to lubricate the gearbox. So i towed it home 20 miles at 20 mph. Luckily pretty quiet roads and no incidents I'm hoping the gearbox has survived. The distance and speed seem to be within most boundaries i've seen on the internet. Unfortunately i won't know until i have removed it, sold it and someone else has fitted it * In the later Zafira handbook it says autos should be towed below 50 mph for less that 60 miles so fingers crossed And just for fun here's the critter. Pretty good condition really
Have a look at the manual. Usually, there is a section about towing.
Have a look at the manual. Usually, there is a section about towing. That would had been my suggestion, some Autos you can flat tow for a limit mileage at a certain speed.
If I'd had access to a handbook before towing I would have checked. Failing that I went with the conservative advice I had
Hopefully, if the Zafira B is to be used as a guide, I was well within the limits
Feb 13, 2018 20:48:46 GMT
For those that say it can’t be towed because it’s auto, you’re wrong.
Semi-Auto and Auto HGV’s are towed daily.
Disconnect the prop shaft, you’ll be fine!
Feb 13, 2018 22:10:07 GMT
For those that say it can’t be towed because it’s auto, you’re wrong. Semi-Auto and Auto HGV’s are towed daily. Disconnect the prop shaft, you’ll be fine! Sure, if I had gone prepared to remove the driveshafts I could have driven quicker but that's quite an involved job to do on a public road outside someone's house Or if I had one I could have used a dolly Or, if I knew the engine wouldn't idle I may have taken a trailer If all this isn't possible you end up towing an auto 😋
sal
Mk2 Cavalier CD
Feb 16, 2018 19:59:51 GMT
So you bought this car as you sold previous owner a bad engine. After having towed the car home you intend to sell the auto box not knowing if it’s damaged or not? I can seeing you buying that auto box back fitted to another car shortly.
Feb 16, 2018 20:07:11 GMT
Yes, I will sell it not knowing if it is damaged or not
The reason being that on the balance of probability I believe it isn't
Feb 16, 2018 20:13:35 GMT
The term 'Schroedinger's cat' springs to mind.
Feb 16, 2018 20:15:55 GMT
There is no reason to think there is a problem with the gearbox
sal
Mk2 Cavalier CD
Feb 16, 2018 20:22:53 GMT
Feb 16, 2018 20:25:29 GMT
I'm hoping the gearbox has survived. The distance and speed seem to be within most boundaries i've seen on the internet. Unfortunately i won't know until i have removed it, sold it and someone else has fitted it There is nothing to suggest there is a problem with the gearbox
Feb 16, 2018 20:42:19 GMT
Sal, I feel you are accusing me of being a reckless seller who is happy to supply a part not knowing (and not caring) if it works or not
I can assure you this is not the case
The engine supplied for this car used to be in my Dad's Zafira which up until the point of being taken apart was running perfectly. When told that after being delivered to his Grandma the engine was making a lot of noise, and he diagnosed it as the bottom end, i had little choice to accept the situation regardless of my previous knowledge of it. I could have refunded the price of the engine but instead decided the buy the car and paid what it had cost them to this point car+engine
When deciding to tow it back i established (based on numerous accounts both professional and personal comment) a safe speed at which i could be confident in looking after the gearbox. Obviously if i was careless i would have driven the 20 miles at 60 mph
When i say i hope it has survived it is just a statement of truth. Of course i hope it has survived and it is unfortunate that because the engine won't idle i can't test it. But based of how i treated it and the previous owner's experience i believe there is no problem
Everything i sell is covered with warranty and although some may think that means i don't care as i'll just refund that's simply not true. The last thing i want as a seller, predominantly on ebay, is for things to come back me as it costs money, creates grief for me and the buyer and damages my reputation
James
sal
Mk2 Cavalier CD
Feb 16, 2018 21:07:25 GMT
I’m not accusing you of anything I’m simply commenting on a post you made where you state you hope that the gearbox has survived but you won’t know until you sell it and someone else fits it.
Feb 16, 2018 21:09:01 GMT
Ok
