Jan 28, 2018 18:20:17 GMT
Front Bumper in fair condition: £15 Located in Finchamstead (near Wokingham), fairly close to both Junc 10 & 11 of M4. I have a mad plan for the seats, rear axle & front subframe etc (which probably includes the wheels) but pretty much all the rest is available if anyone needs other parts. It was in reasonable condition when laid up but unfortunately its been vandalised by some idiots. However pics should give an idea of what remains (no engine but 4-speed + OD G/B is still there):
Last Edit: Feb 12, 2018 20:16:38 GMT by brickie501: Pic of bumper added
tofufi
South West
Jan 28, 2018 19:45:44 GMT
Does it have air-con? I could be interested in a number of under-dash bits if so
Jan 28, 2018 20:00:27 GMT
Does it have air-con? I think so - I've just spent the afternoon removing, amongst other things, what remained of a condenser rad out of the front end! Bits of the dash trim / glovebox have been pulled out (to get to ECU I think) but I think most of the under-dash stuff is there. I'll try & take a pic under there tomorrow...
tofufi
South West
Jan 28, 2018 20:05:03 GMT
Excellent, thanks. If it does, I could be interested in the plastic heater box (if the recirculate servo holds air) and several bits of the ducting which lives under the dash... Servo... (but I'd take the whole heater box) - the one in the passenger footwell is the recirc one. And at least items 7 and 10... I could also be interested in the glovebox and a few of the other under-dash plastics. If the tailgate handle isn't too knackered I'd probably take it as a spare too if the price was right
Last Edit: Jan 28, 2018 20:05:49 GMT by tofufi
Jan 28, 2018 20:25:39 GMT
I think the glovebox is knackered unfortunately...
I'll see what I can get out unscathed, although it won't be until next weekend before I can really get in there.
On the plus side I'm in Bristol (Filton area) on work fairly often & could probably drop stuff off somewhere closeby!
tofufi
South West
Jan 28, 2018 20:49:46 GMT
No problem on the glovebox - I only need the inner bit even if just as a template to experiment with mine The heater box comes out with about 8 10mm nuts which go through the firewall from the engine bay side - from memory it's two around where the heater pipes go through, 3 on the a/c side, with another one hidden below the a/c connection, and another two in the middle somewhere That's a bonus about Filton - I'm due to be heading past your way with work sometime soon but Filton would be even more handy
tofufi
South West
Feb 12, 2018 14:51:08 GMT
Huge thanks to Rob for the heater unit from this car. Really nice guy, and there's still some good usable bits on the car if someone wants anything
Feb 12, 2018 20:14:31 GMT
You're welcome Jim, hope those parts help get yours sorted! Front end panels are in really good condition, the inner wings should give an idea of how clean this car is despite sitting in a hedge for years. Its impressive how easily everything has come apart; excellent Volvo build quality & no rusted out fasteners! Front wings & bumper have simply been removed for safe keeping - they are available if anyone wants them. To give an idea of what else is still there, this is how the car stands as of today: As per initial post, I want to keep the running gear &, probably, the front seats for a possible project. Anything else, just ask!
