Sorry if this isn't the right place please move to the correct section if needed.
Basically I have an old nissan gloria with an old analog tv screen. The TV is used to display sat nav & traffic, tv, cd, tape & radio functions.
On the separate display there is also function buttons for the aircon & heater.
None of the surround works to adjust or select each function.
Also the aerial doesn't work but I'm unsure if this is because I can't select radio on the front facia to active the aerial.
Here's a few pics to explain. I have used Google translate so I know what each button does.
The cd player & tape deck work but I cannot change track or volume etc due to surround not working.
What I'm after is a clever auto electrician in the Bristol area that can help. I can pull all the dash & trim out if that's needed.
Any help would be great.
