Jan 25, 2018 15:11:53 GMT
Hi all Going to try citric acid to remove some rust on old tools etc (trial run for car parts) Got the mix ratio (1 heaped tablespoon / litre water) but my question is simple, do I mix it with hot, warm or cold water ?? Thanks
Jan 25, 2018 15:21:50 GMT
Cold water and always add the acid to the water, not the other way round. The reaction is exothermic so can boil small quantities of water quickly.
Jan 25, 2018 23:09:22 GMT
Not with the amount of citric you're using it's not!
I've added it straight into boiling water, no issues. Hell, you can oversaturate water with citric crystals and it won't get warm....because it's not exothermic, it's endothermic, it takes far more energy to break down the crystals than you get with the acid hydration.
Last Edit: Jan 25, 2018 23:15:34 GMT by phillipm
Jan 25, 2018 23:50:08 GMT
Ok Many thanks
Jan 26, 2018 11:09:24 GMT
I used warm water rather than cold just because it seems to dissolve better - I find I can be stirring the jug for quite some time with cold water. Same for washing soda crystals. 10% concentration is the mixture I use, I've never tried it stronger.
Jan 26, 2018 14:30:47 GMT
Thanks Going to try some old stuff first as a trial run Makes sense about disolving better in warm water though
Jan 26, 2018 16:15:51 GMT
It'll also work a lot faster if you keep the water hot.
v8
Jan 27, 2018 10:25:26 GMT
I used hot water straight from the tap and mixed in as much acid powder as would dissolve.
Stripped of rust and old Zinc plating no problem, it works far better in warm weather and parts need to be de-greased first.
stuey
ram thruster 4000
Jan 29, 2018 19:16:26 GMT
try oxalic acid you can buy it from ebay its great for de rusting and works wonders on chrome.
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Jan 30, 2018 10:37:16 GMT
I've used that to good effect when the item I want to clean is bigger than the amount of citric acid I'm prepared to mix. Washing soda is so much cheaper than acid powder. Milkstone remover is pretty effective too, as is a product called "ph Down" (sold for hydroponics) as they are both some type of acid that removes rust - I can't remember which one and don't want to guess.
