Jan 16, 2018 22:09:20 GMT
Here's my parcel shelf: 6" original speaker hole in the middle, two sets of 10cm holes as well. I've got some speakers to go in them, but which set? Outside or inside? Got some vinyl to retrim it, probably will sound deaden the shelf as well while I'm about it, and as a bonus I get to ditch this horrible thing: I'm not going to tell you which way I'm leaning, I just want to know what people think
ivangt6
Club RR Member Number: 132
Jan 16, 2018 22:46:18 GMT
I prefer the speakers further outboard. Maybe you could make up some vintage looking speaker pods. Faced with something like this
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
Definitely outside - the widest space as possible is the way to go.
Even better if they were in front!
Jan 17, 2018 12:45:00 GMT
Get 4 and a base in the middle
Jan 18, 2018 11:43:10 GMT
The woofers can be closer to the center, but the midrange and tweeters should be outside as far as possible
Jan 18, 2018 18:07:29 GMT
I’d ignore them all & cut two more
Jan 18, 2018 19:02:31 GMT
Definitely don't cut additional holes in the steel as it reduces the structural integrity of the body shell. Pretty sure it's not even legal to do that here in New Zealand. As others have said the wider apart the speakers are the better the sound quality so use the outermost holes. Elwoody makes a good point. I too would be inclined to save the original upholstered shelf as it looks too good to destroy, and make a new one to suit.
Last Edit: Jan 18, 2018 19:03:41 GMT by igor
Jan 18, 2018 20:12:09 GMT
I've gone with the outside holes. The old shelf already has had holes drilled and cut in it to fit the high level brake light and is quite tatty so I've recovered it, but I might get a bit of MDF instead. I drastically over-ordered when I got the vinyl, I reckon I could cover ten shelves with what I've got!
A bit of MDF though would also mean I wouldn't have to even drill the metal, so I'm inclined to do that now.
