Jan 15, 2018 14:52:57 GMT
SOLD Mercedes Genuine workshop spring compressor, having a clear out at home before we move, for a S Class W116, part number 116589063113 £60 plus postage £7.99 insured signed and tracked service, Or 5.99 with no signature or insurance but tracked.
Last Edit: Jan 29, 2018 7:17:57 GMT by rusty998
MK2 Cortina Estate
Jan 15, 2018 16:28:34 GMT
Hi Rusty,
do you know if either will work with a w126?
many thanks
Jan 15, 2018 16:38:47 GMT
Edited my original answer. After reading info on W116 and W126 it looks like the springs are the same, The difference between the two is lower arm's and thicker spring bushes, I hope the info I have read is correct but happy to be proved wrong, The spring compressor you need will be the W116 one 116589063113
Last Edit: Jan 15, 2018 18:30:20 GMT by rusty998
MK2 Cortina Estate
Jan 28, 2018 16:23:39 GMT
190e compressor sold W116 reduced price to £60
MK2 Cortina Estate
Jan 28, 2018 18:04:27 GMT
£55 including postage?
Jan 28, 2018 18:13:23 GMT
I have sent you a message Carat 3.6
MK2 Cortina Estate
Jan 28, 2018 21:08:13 GMT
Why were the springs so troublesome/dangerous to remove? They are mounted inboard, and are shorter but much stiffer. I've heard of regular spring compressors flying off or bending...!
Jan 28, 2018 21:55:24 GMT
I've seen one on a v8 r129 snap the end off the normal type compressors, it came back out of the wheel arch like a shot from a gun!
