joda
I have recently installed a large wood burner in the garage, however i need to move the air around, so i have made a heat exchanger from a 25ltr barrel and 12volt car electric radiator fan.
My problem, the fan spins to fast at 12volt, i need a resistor/control module that i can use to reduce the speed.
I purchased one from ebay for £6 which worked a treat, however it went on fire after 30seconds of use.
I'm looking for a cheep, of the peg solution, anyone have any suggestions?
get to a scrapyard and find a low speed cooling fan resistor, pretty common on older pre canbus/multiplex single fan twin speed french things.
You may be able to use a pulse controller switching a relay. That would give you more variations in speed too.
1988 DUTTON LEGERRA MK1 - SPARES DONOR 1989 DUTTON LEGERRA MK2 - CURRENT PROJECT 1990 DUTTON LEGERRA ZS MK2 1990 DUTTON LEGERRA ZS MK2 DUTTON PHAETON S2 - Resting DUTTON PHAETON S4 - Resting DUTTON PHAETON S4 - PROJECT X DUTTON SIERRA S2 - Resting
Dec 10, 2017 22:57:02 GMT
Last Edit: Dec 10, 2017 23:04:42 GMT by fuldatramp
village
Always carries a toolbox. Because Volkswagen.......
Dec 12, 2017 15:39:16 GMT
Don't slow the fan down , fit a smaller set of blades.......
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
jimi
Dec 13, 2017 23:10:25 GMT
Fit a 24v fan, it will run at approx half it's rated speed on 24v
Dec 15, 2017 18:52:22 GMT
get a stove fan. they are on ebay. work by some kind of witchcraft, they just sit on top of the woodburner and get going once it gets up to temperature. they just move the air around, and they work very well, the hot air coming from the top of the stove gets blown around rather than just going straight up, the woodburner is the only heating we have in our bungalow and the fan just moves the air to equalise the temp everywhere. and after the initial cost (about £30) they use no electric or batteries. really worth looking into.
Toyota mk3 supra. retro goodness.
Dec 15, 2017 19:59:36 GMT
Wire in a single headlamp bulb - the more bulbs you add, the faster it will run.
