For sale:
Golf V intercooler
Renault 5 GT intercooler
NB MX5 passenger side electric window regulator
Brand new motocross helmet and goggles
Metro turbo T3 elbow
Maestro T3 elbow
T3 3 bolt wastegate housing
K&N cone filter
First intercooler is from a Golf Mk5. It's big, a little too big for my Avenger project as the bonnet won't close. Pretty mint condition. Has snap fit type connectors and the effective inner pipe diameter is 2.25".
£15
IMG_20171129_132121 by Chris Witkowski, on Flickr
IMG_20171129_132203 by Chris Witkowski, on Flickr
Next is I believe a Renault intercooler. It's a double pass design with a thermally controlled valve which bypasses the core at low boost/temperature. 2.25" pipe connections.
£20
IMG_20171129_132148 by Chris Witkowski, on Flickr
IMG_20171129_132138 by Chris Witkowski, on Flickr
MX5 Nb passenger side electric window regulator. Works fine. I don't know if it fits NA models.
£15
IMG_20171129_132214 by Chris Witkowski, on Flickr
Next up is the motocross helmet. It's never been used. I bought it new and it sat in my house in the box for a number of years. Lazer brand, size M (57, 58). Absolutely perfect condition, with brand new Oakley goggles, also perfect condition, with tags for tear offs. Both still have labels attached.
£50 for both.
IMG_20171129_123640 by Chris Witkowski, on Flickr
IMG_20171129_123410 by Chris Witkowski, on Flickr
IMG_20171129_123229 by Chris Witkowski, on Flickr
IMG_20171129_123348 by Chris Witkowski, on Flickr
Metro turbo T3 elbow. A bit pitted on the outside but usable.
£15
IMG_20180206_141020 by Chris Witkowski, on Flickr
IMG_20180206_141006 by Chris Witkowski, on Flickr
Maestro/Montego?? turbo T3 elbow. Good condition.
£15
IMG_20180206_141033 by Chris Witkowski, on Flickr
IMG_20180206_141025 by Chris Witkowski, on Flickr
T3 wastegate housing. The wastegate shaft itself is slightly bent and will need replacing. Otherwise good condition.
£10
IMG_20180206_141136 by Chris Witkowski, on Flickr
IMG_20180206_141143 by Chris Witkowski, on Flickr
K&N cone filter. Slight surface rust beginning on top. Will need cleaning and re-oiling. Fits onto 2 5/8 (65ish mm) pipe.
£10
IMG_20180206_140300 by Chris Witkowski, on Flickr
IMG_20180206_140328 by Chris Witkowski, on Flickr
IMG_20180206_140307 by Chris Witkowski, on Flickr
Can post if necessary. Items all located in Huddersfield.
Golf V intercooler
Maestro T3 elbow
K&N cone filter
£15
£20
£15
£50 for both.
£15
£15
£10
£10
