Nov 27, 2017 20:52:56 GMT
i have a 1993 metro which is currently being modified in to a van i am using all the parts off a scrap metro van, window blanks, van bulkhead and floor extension an original metro van is a 'car derived van' on the log book do i legally need to change body type to a car derived van or can i just leave it? would it need inspection to change body type?
Last Edit: Nov 27, 2017 20:57:24 GMT by vauxviva
Nov 28, 2017 17:53:07 GMT
I believe you would need a BIVA as you are altering/ modifying the shell.
Nov 28, 2017 19:31:56 GMT
thanks for reply
i haven't altered the original shell the rear bulkhead/ floor extension is bolted in
the side window blanks are bonded/spot welded in the original window holes
is adding window blanks classed as modifying original shell?
if so it is not a issue as i would simply remove and make them bolt in
Nov 28, 2017 20:12:15 GMT
thanks for reply i haven't altered the original shell the rear bulkhead/ floor extension is bolted in the side window blanks are bonded/spot welded in the original window holes is adding window blanks classed as modifying original shell? if so it is not a issue as i would simply remove and make them bolt in Sorry I thought you meant the engine bulkhead, window blank plates wouldn't count as because you are not altering the body.
Nov 28, 2017 20:25:18 GMT
no problem
my main question is
because i have removed side windows and added a rear bulkhead and removed rear seats creating a load space
should it be now classed as a car derived van or is it still a car
i can't seem to find any info on internet if i need to change body type on log book or not
Last Edit: Nov 28, 2017 20:26:31 GMT by vauxviva
Nov 28, 2017 20:30:19 GMT
it wont change the taxation class so I doubt you need to bother at all, it still looks like a metro.
