This wonderful bit of kit has been sitting in my garden for a couple of years now, and I will not be needing it again now that the Midas is back on its wheels. It's effectively the bottom of a warehouse cage trolley with the cage cut off. The (very) large castors at one end are on a fixed axle, whilst the front ones turn. It's really heavy (solid metal frame with a wooden baseboard) but should fit in the back of a decent sized hatchback quite easily. It now has orange overspray on it as well! Could also be used for an engine trolley although it's a bit unwieldy!
It's too good to throw away.
Needs to be collected from Central Ipswich, ideally ASAP.
As modelled by next door's cat, Fat Fred.
With Midas for size comparison, about to go under it.
It will also quite happily take a small bodyshell on its side, as shown here.
