Thought Id start a thread here as always lurking Bought the shell Stripped it and removed wiring loom Adapted spare widetrack kit from a corsa that we have,so that its 50mm wider in each corner Test fitted widest wheels that will be run to get an idea of how it will sit
Had a rotten shell and made wide arch kit Here are the moulds
Started cutting bits of rust out such as battery tray and removed strut tops Converted the Koni shocks to coilovers with a kit from JJC just to speed up the process of being able to put wheels on it when we move projects in and out of the garage
Test fitted the wide arch front wing basic shapes Welded up the strut top plates
Got the front cross in Tacced up most of the cage Somewhere down the road mounted power steering and column Sill stands
Test fit the K20 from another project Tacced up mounts Needed the K20 for another project do picked up another for a bargain no idea what state its in though
Vauxhall Nova K20 PowerChasR
@chasr
Club Retro Rides Member 170
It certainly looks like a fun project! It will be interesting to see how this goes.
ChrisT
Club RR Member Number: 225
Vauxhall Nova K20 PowerChrisT
@christ
Club Retro Rides Member 225
Looking good, k20 is an s2000 engine then?
Mocked up driveshafts Honda to Vauxhall Started on clutch setup Shortened power steering unit
It certainly looks like a fun project! It will be interesting to see how this goes. Thanks Chas
Looking good, k20 is an s2000 engine then? Thanks Chris the F20 is out of an S2000, this engine is out of an EP3 like this one here
Had to drop the floor and remove cross brace to give more headroom and legroom
Nov 17, 2017 10:05:07 GMT
Plated the dropped floor, modified a slimline seat slider, test fitted seat and started some 'CAD' for the new cross brace with hydro on top Work on the cross brace is a go with hydro mount
Nov 17, 2017 10:20:08 GMT
Few other bits dotted through the timeline of the build Tacced up shifter mounting Mounted bottle Modified throttle pedal Sat rear arch mould on car to see how it looks
Nov 17, 2017 10:35:23 GMT
düdo
wide as house
Nov 17, 2017 11:12:08 GMT
Impressive work. A friend had a similar model standard Nova around about '91 which he called 'No Va' from the Spanish for 'doesn't go' due to its unreliabilty - this looks as though it will go!
I was looking at a V6 Corsa A this morning ( same body as your Nova), the owner said that outside of 'sleeping with the TÜV inspector' it will never get papers. Here in D modifying is a nightmare. Your creation would be almost impossible to get registered here! Keep up the good work
Nov 17, 2017 11:16:13 GMT
This'll be a weapon when finished! Track use or road?
Nov 17, 2017 11:26:20 GMT
Nov 17, 2017 12:07:02 GMT
This'll be a weapon when finished! Track use or road? Thanks should be Track and Tarmac Rally maybe even some Time Attack
