taurus
Nov 11, 2017 16:56:29 GMT
I came across this at the Riverside Museum in Glasgow (great place to visit, I think it used to be called the Museum of Transport) I guess it was fitted inside the vehicle being tested and measured the braking force exerted on the paper graph. Anyone able to confirm or correct that assumption?
Nov 11, 2017 21:37:20 GMT
It looks a little like the British Pendulum Test apparatus used by engineers to measure the skid resistance of a road surface. That being the case your assumption may well be correct.
Nov 14, 2017 20:46:39 GMT
The olde-worlde MOT brake testers I've seen have a window to display the braking force. I'd guess the one you saw does a similar job but was never MOT related, best suggestion so far is from igor
squonk
Nov 17, 2017 20:36:04 GMT
The olde-worlde MOT brake testers I've seen have a window to display the braking force. That would be a Tapley meter Looks like the one the OP has posted a picture of is a variation of the brake tester, probably older than a Tapley meter though. Don't appear to be worth much!! www.bonhams.com/auctions/18219/lot/247/
Last Edit: Nov 17, 2017 20:39:31 GMT by squonk
Those things are still used here.
