Been a while since I've been on here mostly because I don't really own anything old anymore, nor have I had any good enough projects until this one!
Little history of the bike. This is what I bought after I sold my CZ125 (which I also did a thread on). Started life as a 50cc Skyteam Monkey I bought for £600 with 200km on it...
DSC_1756 by Jack Ledingham,
I faffed about with it for a bit but quickly bought a 125 engine out of a Dax copy with 500km. I bought a VM22 and rejetted it to 17.5/105 with a foam filter. I also bought a 29mm bore exhaust meant for a CRF50 and made a bracket to fit the monkey. It was only £27 new and while it was only intended as a short term job I actually reeeeally like (now its been re-riveted so isnt rattling itself to bits) it so its staying. It did put holes through about 3 pairs of trousers though so I ended up wrapping the knee touching bit with heat wrap. I regeared the bike to cruise at 50/55 mph. Had to buy a longer clutch cable so bought a red one for a pit bike and shortened it. Then I fitted a rack for what I was about to do next which was very silly...
DSC_1832 by Jack Ledingham, on Flickr
DSC_1837 by Jack Ledingham, on Flickr
DSC_1838 by Jack Ledingham, on Flickr
DSC_1842 by Jack Ledingham, on Flickr
DSC_1851 by Jack Ledingham, on Flickr
DSC_1862 by Jack Ledingham, on Flickr
DSC_1863 by Jack Ledingham, on Flickr
Because the next thing very silly thing I was doing was the North Coast 500... Leaving from Aberdeen. Which when I worked out the route was about 900 miles for us to cover in 4 days. Camping and carrying everything on the monkeys. Aside from the Friday when we left which rained all 200 miles to Applecross, the rest of the weekend was glorious sunshine T-shirt weather and we had a cracking time! Here are a some photos.
DSC_1878 by Jack Ledingham, on Flickr
DSC_1881 by Jack Ledingham, on Flickr
DSC_1882 by Jack Ledingham, on Flickr
DSC_1886 by Jack Ledingham, on Flickr
DSC_1888 by Jack Ledingham, on Flickr
DSC_1893 by Jack Ledingham, on Flickr
DSC_1892 by Jack Ledingham, on Flickr
DSC_1898 by Jack Ledingham, on Flickr
The trip went fairly smoothly. Believe it or not fuel wasn't an issue and I never needed to use my spare can. My swing arm broke in Ullapool and the only threaded bar that the hardware shop had was 8mm or 12mm. I opted for 8mm wrapped in Gorilla Tape with penny washers and double nuts at each end and it lasted the whole way back without an issue! The exhaust also tried to rattle itself to death and my rear tyre had suffered.
Then when I got home a couple of weeks later I hadn't been using the monkey. I got the hankering to build another cafe bike so put the monkey up for sale. But I felt like after how good the monkey had been to me I didn't like the idea of seeing someone else take it away! So I did a bit of research and realised I could make a pretty silly cafe bike out of the monkey. I went and bought some bits. Michelin S83 tyres, Cafe seat, drop bars, new grips and a discreet splash guard to get rid of the rear mudguard.
While I had the monkey in bits I also did a total wiring tuck and shortened a lot of the harness to be a lot neater and sit on top of the frame. I also flipped the headlight brackets to drop it down about an inch. I fitted some LED indicators I had in my toolbox to the front and fitted a really trick rear tail light/indicator LED strip to the seat hump as a rear light. I stuck some thicker fork oil in to deal with the weight of myself leaning on the bars a bit more and gave the thing a general tidy up.
DSC_2173 by Jack Ledingham, on Flickr
DSC_2174 by Jack Ledingham, on Flickr
DSC_2176 by Jack Ledingham, on Flickr
DSC_2179 by Jack Ledingham, on Flickr
DSC_2186 by Jack Ledingham, on Flickr
And this is her complete:
DSC_2190 by Jack Ledingham, on Flickr
DSC_2192 by Jack Ledingham, on Flickr
DSC_2193 by Jack Ledingham, on Flickr
DSC_2194 by Jack Ledingham, on Flickr
DSC_2195 by Jack Ledingham, on Flickr
DSC_2196 by Jack Ledingham, on Flickr
DSC_2197 by Jack Ledingham, on Flickr
DSC_2198 by Jack Ledingham, on Flickr
Then finally I made up a decal for the side panel. I'll probably end up making an aluminium flat panel at some point but this will do in the meantime!
DSC_2201 by Jack Ledingham, on Flickr
The end result is an absolutely tiny Cafe Racer with stupidly quick handling and does nothing but make me laugh and smile every time I even see it let alone ride it. So basically the rest of this thread is going to be me doing silly things on the monkey and taking it to shows. I've done the touring thing so thats out of my system. Enjoy.
