Sept 29, 2017 20:52:01 GMT
Hi,
Looking for a good quality normally open relay, which I can use to energise the fuel pump on a 2005 BMW, I basically want to have a fuel pump kill switch,
I'm looking for a good quality relay, hoping to keep away from a cheap relay that will probably catch fire.
Anyone know where I can get a quality one?
Thanks.
squonk
Sept 29, 2017 22:19:28 GMT
Last Edit: Sept 29, 2017 22:19:53 GMT by squonk
Sept 29, 2017 22:19:41 GMT
RS.
- '88 MK2 Golf 1.3 c - '07 BMW E91 335d - '94 T4 1.9d
melle
South West
It'll come out in the wash.
Sept 29, 2017 23:16:02 GMT
Get a Bosch relay from the scrapyard?
froggy
Sept 30, 2017 12:16:29 GMT
Yep quality oem relays from a scrapper , I used ones from a 2000 micra which are still standard sized ,
Good quality relaysChasR
@chasr
Club Retro Rides Member 170
Sept 30, 2017 14:33:01 GMT
Scrapyard as said. I have tons of Ford relays if you want one.
Bosch pink relays, they're used on central locking and fuel pumps. You'll find most relays do the same thing and are designated the same function names. Your switch will be doing the same thing the ECU is doing - powering up a coil that will close a switch and power up a fuel pump etc. I've somehow amassed loads of these.
Last Edit: Oct 1, 2017 20:38:13 GMT by DavidB
