Hi all I am selling my eunos due to wanting something different
It's an 1992 eunos imported in 2007 (original import documents in the history folder) it's never been welded but has had a previous re spray as the previous owner said the paint work was faded in places. It's done 70,000 miles and the speedo has been changed to mph.
2 owners from when it was imported in 2007 and sailed through its m.o.t last month. Soft top in good condition and does not leak
I've done the following things to it over the past two years...
. New disk and pads all way round. Fronts are drilled and grooved. Painted the callers yellow
. De cat pipe which is legal for m.o.t due to its age and being an import
. Headlamp scoop
. New thicker heavy dutie ht leads
. New lamba sensor as emissions was high on its m.o.t when I first had it m.o.t in my possession back in 2016. Bang on now from latest mot
. All of the underneath is under sealed
. I've painted the daisy wheels graphite grey with yellow Mazda centre cap cymbals
. New anti roll bar links all way round
. Mazda eunos decals on either side
. Front grill painted black with yellow toe eyes
. Brand new radiator fan as old one had packed up on.
. Dash light bulbs replaced as some had burnt out
.New rad top hose as the old one had split
. Heat shield installed on the k+n filter
Bad points
.Air con does not work but never bothered me as top is down all the time.
. Clutch biting point a little high but never slips
It has had a bit of a pampered life in my possession always garaged and Only used it mainly when going to car shows in summer. I have sorned it every winter (oct-Apr)
Took me ages to find a good one and I performed a previous mot checker before buying the car. Noticed on every mot there was an advisory on the brakes just making efficiency hence the reason why I replaced both front and rear brake pad and disc
Does not smoke or use water/oil pulls really strong through the gears. I have Had it since November 2015
The pictures are what I have in my phone I am happy to take further pictures of the engine bay which is clean along with the under side
Located in Sheffield £2000
. Headlamp scoop
Bad points
