Sept 12, 2017 11:56:02 GMT
No I wasnt on about that, i was on about what would happen to the tax I'd be paying on a £30 tax Lupo IF any conversion occurred and gave a couple of common Lupo conversion scenarios of 1.8T and 4 pot TDI.
The point was if the £30 tax band was preserved or not. It isnt. So in my mind it is a shame to waste a £30 tax Lupo when there are plenty of other petrol donors about that I'd be happier with the resulting tax hike doing a conversion on.
mk2cossie
Club RR Member Number: 77
VED and engine conversions?mk2cossie
@mk2cossie
Club Retro Rides Member 77
Sept 12, 2017 12:59:02 GMT
Whatever route you take, just remember that the diesel engine will still need a catalytic convertor for the MoT emissions test
Sept 12, 2017 14:07:11 GMT
Unless that is a recent change mine is already minus a cat and MOT no problem.
Sept 12, 2017 14:33:45 GMT
has been a thing a few years, if it came from the factory with a cat they are meant to stay.
nothing to do with emissions test though as a diesel will still pass without.
mk2cossie
@mk2cossie
Sept 12, 2017 18:00:39 GMT
That's it. Diesel test is for smoke opacity, and a visual check for the cat being there. If it isn't, and you are unlucky enough to get a DVSA roadside check it's bound to get at least a finger wagging and the MOT tester flagged most likely
