Apparently the coil on my XE Manta should be 0.35 Ohms across the primary windings, I'm getting 1.0/0.9, probably the reason for lack of spark....
Thing is I can't find a coil that's anything like the one I've got, apart from a Weber Performance pdf file where it's listed in parts (WIC003) but even using that doesn't bring up any results.
Is there any reason why I can't use a 'normal' coil, as long as it's got similar spec to that one?
It's for a C20XE on carbs with distributor and Weber Alpha ignition.
