Hello, have been thinking of making thread out of this for long enough now so time to do it. Bought it about 2 and a half years ago, mainly because i was in need of daily driver which i could dump asap when i could afford better, and definately not to fix if it has major problems. Well, i'd say thats not how it went according to time and money spent fixing it. Its 1.6 8v with Pierburg 2e-e carb(which works surprisingly well at least for now altough idle is rough), I've put 25-30k km:s on it and it has around 250k:s on odo.
List of problems and things to do soon
-Exhaust leaking, brand new mufflers in trunk, just haven't replaced it yet.
-Front control arm bushings installed wrong, probably causes weird torque steering when decelerating in high speed
-Fit front anti-rollbar
-Wire those daytime running lights in front
-Fit the original rearwing that used to be there but carwash decided to remove it.
-Change coolant
-Clean interior
-Front brake discs look like they need replacement.
-get another daily so could work more with this
Things i have been planning when possible, cant promise anything tough.
-Get rid of all the rust
-Repaint
-Sorting engine problems.
Then got set of RA:s for summer
Bad quality pic of what it looked like when i last saw it
Should also get new rear springs or lower the front ones
Some rust fixes i've done to it.Went bit lazy with the first one's painting because black was only color i had.
-Change coolant
-Clean interior
-Repaint
And here's some pictures of it, every comment is welcome
This is taken this years may i think, just after i had fit those Hella daytime lights.
