The alloys I have been hunting for years finally appeared on ebay - Purchased and got them back to mine to check the fitment (4x108/et40/7J/15 inch)
I need to make the spigot bigger on them by 1.5mm which isn't a problem as a local firm can sort this for me - but only on two of them.
When on the rear it fouls the suspension arm - but clears (just) with the use of a 5mm spacer.
Not having any experience of these things before, as it is only 5mm do I still need to get longer wheel bolts?
The clearance is very tight but ok - Apart from not going for tyres that are too wide is there anything else I need to consider?
The wheels purchased also came with some very well made aluminium inserts but I have no idea what they are for - anyone know?
Pictures.
Pictures.
