nel5on
West Midlands
Jun 22, 2017 19:58:33 GMT
I replace all the rear bushes, and it felt better, got a wheel alignment done. Now in faster longer corners, I drive it in, and hold the wheel, then in sections the car dives into the corner further and releases, so seems to be fighting it in the corners.(feels like the wheel tucks under)
I can assume a few things, alignment is out, or new rear bushes put extra loads on the front end and something is letting loose? Checked front wheel bearings, and all front bushes, no real signs of wear or movement, shock tops look OK, ball joint have worn rubber covers, ARB connecting rods feel good... Back bush bolts still seem tight.
What could my problem be?
Might get the wheel alignment checked again tomorrow... Thanks in advance.
Covin 996.2 Tucson
Jun 22, 2017 20:31:25 GMT
Bent anti roll bar or soggy drop links ??
Jun 22, 2017 20:58:21 GMT
sounds like dampers to me.
Jun 22, 2017 21:15:48 GMT
tyres?
Jun 22, 2017 21:24:22 GMT
Is it the awd model? Could the system be doing something odd with power transfer?
Jun 22, 2017 21:25:21 GMT
I've driven cars with the front ARB removed/ missing drop links and they feel like this. Maybe the front ARB has snapped? it's a bit far fetched but your description is exactly what I felt.
Jun 22, 2017 21:48:56 GMT
My Vitara did that, bottom ball joints on the front were buggered
Maybe the DSC system braking one of the front wheels to help the car hold its line? have you tried it with traction control and any DSC type systems turned off?
nel5on
West Midlands
Jun 23, 2017 10:39:07 GMT
Appericate the hints on what to check...thank you. Balljoints are not so good, but this feeling is new. Got it aligned again today(not fixed it), yes they said it was out, and checked other stuff, said one drop link was not too tight but no real bad movement. While everything in the front need replacing...now is not the time(holiday next week) and it all still looks usable. Considering a rear leaking shock....it might be letting go, and diving the front.
Covin 996.2 Tucson
Midas
Club RR Member Number: 14
Jun 23, 2017 14:14:47 GMT
I'm not familiar with the suspension set up on these, but what is controlling the rear toe angle and is it worn/fitted incorrectly/loose etc?
Jun 23, 2017 19:49:52 GMT
Live axle on the rear on a pair of trailing arms and a single top link.
Ryannn
Jun 23, 2017 20:20:25 GMT
Had a very similar problem today with a mini, swapped a rear tyre which didn't feel to be wearing flat and problem solved!
rbs
Jun 24, 2017 21:51:06 GMT
Not familiar with the XC90 but all the BMW AWD vehicles are super critical on tyres. Not only do you need to have BMW approved tyres fitted to avoid transfer box wind up and subsequent damage but the tread depth has to be reasonably equal on the same axle. That moght be your problem so worth looking at.
Midas
Jun 24, 2017 22:23:31 GMT
Live axle on the rear on a pair of trailing arms and a single top link. Nothing too technical there then.
I'd also say dampers.
The fact that you've had the wheel alignment done would also do this ; the toe of a car can surprisingly bring about more grip if it's way out which also will induce more roll.
nel5on
West Midlands
Jun 27, 2017 19:53:34 GMT
replaced 2x front ball joints, had almost 2mm play in them when loose....problem still not fixed. Shock wont come until next week....I advise when this is fixed also.
Covin 996.2 Tucson
nel5on
West Midlands
Jul 15, 2017 19:58:03 GMT
Found a bush bolt loose...more than finger tight...total movement could have only been 1mm...but tightened and seems to be fixed now. Thanks for all the direction and hints on possible problems to look at.
Covin 996.2 Tucson
