Hello!
I'm clearing out my workshop and in the process I've found a load of random parts from past projects and other cars which have been through the doors over the years. I'm not 100% sure what some of this stuff is worth, so if I've got any prices wildly wrong just let me know. I've got lots more bits to add over the coming days and weeks, so check back in soon to see if I've got anything you want/need.
Collection from near Dunstable, Beds. I don't mind posting stuff as long as you cover the cost.
First up is a few bits from a 1.6 petrol Skoda Cube van, engine code AEE. After a quick Google, a few other cars which were fitted with the AEE are:mk3 golf, 6n polo, 6L polo/cordoba, 6k ibiza, 9k caddy, 9u caddy and mk1 octavia
Front Nearside hub. Has an ABS ring and sensor although the wires have been chopped - £10
Next are a few parts from a Peugeot 406 1.8 Petrol. These parts all worked fine when removed. The cambelt had snapped. Again, they'll probably fit other models too but I know nothing about Pugs so you'll have to use your own judgement.
Inlet manifold with throttle body - £20
Injector rail & injectors - £7
Coil Pack - £15
Rocker covers - £8
I've also got tons of stuff from Rover 100's/K-series Metros. Too much to photo individually, but here's a photo of it all. If you see anything you want, give me a shout.
- Standard downpipe with lambda sensor
- MPI 8v inlet manifold & throttle body
- MPI 16v inlet & throttle body
- Standard 1.4 brake calipers with discs.
- 8v cambelt covers
- Foglight blank
- Electric window regulator
- Waterpump
- GTI front seats. They are a little dusty from years in storage but would probably come up nice with a shampoo. Couple of small fag burns. My mate threw the passenger one across the workshop because he thought I was binning them, so the subframe is slightly bent but I think it will straighten and bolt up fine.
NEW STUFF ADDED BELOW - 18/06/2017
Wheel bearing for a Citroen. I bought this by mistake when buying a wheel bearing for my Citroen Dispatch. I'm unsure what it fits, but I've taken a photo of the label so you can check the part number. It's brand new and unused although I did open the packet when I went to fit it only to discover it was the wrong part, hence it's got my grubby fingerprints on it.
Another wheelbearing. I'm almost certain this is for a Mk2 VW Polo. A quick google of the number on the box dosn't return much but does turn up VW Polo parts
More stuff added soon!
Coil Pack - £15
Rocker covers - £8
- 8v cambelt covers
- Foglight blank
- Waterpump
