May 29, 2017 18:00:20 GMT
I've not used Nitromors for years but the last time I did it worked VERY WELL, blistering and lifting the paint within a minute or two. But today I used it (not car related) and I can report that it's definitely not the product it used to be. It doesn't blister as quickly or as much and it required a lot of re'applying. Althought it says on the tin that it's stronger and faster acting!.
Have the Environmentals forced them to remove the chemicals that actually make it a good product?.
May 29, 2017 18:03:50 GMT
I have heard it said many times although have not witnesses it . The no nonsense stuff from screwfix has good reviews .
May 29, 2017 18:35:20 GMT
I used some environmentally friendly stuff I got from home base, it was a sort of thick blue gel, it worked very well as I remember.
Rob M
Club RR Member Number: 41
May 29, 2017 18:37:52 GMT
I've not used Nitromors for years but the last time I did it worked VERY WELL, blistering and lifting the paint within a minute or two. But today I used it (not car related) and I can report that it's definitely not the product it used to be. It doesn't blister as quickly or as much and it required a lot of re'applying. Althought it says on the tin that it's stronger and faster acting!. Have the Environmentals forced them to remove the chemicals that actually make it a good product?. Yes, the last time i used it I had to reapply it umpteen times. Doesnt seem like it was what it was. Is anything?
Last Edit: May 29, 2017 18:41:46 GMT by Rob M
OUTRUN
May 29, 2017 18:40:41 GMT
You want a paint stripper containing dichloromethane and phenol. Both removed from Nitromors, now. As a rule, any stripper in a metal tin is sh!te. You want one in a plastic container.
Last Edit: May 29, 2017 18:41:55 GMT by OUTRUN
I need your help to get back to the year 1985.
May 29, 2017 18:52:19 GMT
I used to use nitromors, then one day i bought some and yes, it was utter dross. I tried some Rustins paint stripper and TBH i wouldnt bother looking for anything else, it works really well.
May 29, 2017 19:18:58 GMT
I've been told that to get it to work better, you can wrap the part in cling film after applying the paint stripper. Not tried it yet but will be testing that tip out in the near future. Nitromors and the like have been pretty weak since removing the decent ingredients.
May 29, 2017 19:22:21 GMT
Starchem paint stripper is what you need, pure evil stuff that works a treat.
May 29, 2017 19:45:18 GMT
Yeh it's curse word now, NOTHING like the product it used to be
May 29, 2017 20:23:16 GMT
Starchem Synstrip is what you want, like old Nitromors x100
BT
May 29, 2017 21:51:15 GMT
You want a paint stripper containing dichloromethane and phenol. Both removed from Nitromors, now. As a rule, any stripper in a metal tin is sh!te. You want one in a plastic container. You can buy dichloromethane separately quite easily. Mix this with a standard paint stripper and then you'll have something worth using. I do it with great results.
Dez
Club RR Member Number: 34
May 29, 2017 23:01:57 GMT
Another one for starchem synstrip. I go by the method of if you can get it on your hand and it don't feel like you're re-enacting a certain fight club scene, it ain't going to be worth bothering with.
Another thumbs down from me for nitromors. I bought some to do a couple of bits on the Vespa a while back and it was utterly useless, didn't penetrate at all and I was using the thick application and cover with film method to aid rubbing it in and to stop it evaporating (if that happens) and letting it sit, never even heard the commonly known bacon sizzle.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Nitromors is like wallpaper paste these days.
+5 for Starchem Synstrip. And at around £20 for a 5 ltr (plastic) can it's pretty good value too.
You always know the stuff is good when you unscrew the cap and see vapours escaping like a heat haze out of the neck!!
miaspa
Works just as good for household chores, stripped the banisters in my house rolling resto, used the heat gun first nitromors and wire wool final clean up, works just as well as the last time I used it for the same job different house15 years ago.
Found my flashing Pao again.
slater
Club RR Member Number: 78
I have some stuff at the moment called 'strip away pro' I think. Found it to be a bit better than starchem. Plus one for just buying dicholromethane off ebay tho.
Wilk
I've just used something I bought from a local automotive paint suppliers Looks and works like Nitromorse USED to PBPaints
Nitromors is like wallpaper paste these days. +5 for Starchem Synstrip. And at around £20 for a 5 ltr (plastic) can it's pretty good value too. You always know the stuff is good when you unscrew the cap and see vapours escaping like a heat haze out of the neck!!
Funny that as I keep Nitromors in stock - and the other product we buy from the same company is Solvite Paste lol.
Agree - it's curse word.
May 30, 2017 22:04:15 GMT
I went and got some paint stripper from my local paint place today, it was fantastic don't know what it was called as the container he decanted it from had no branding only some scary looking warning symbols on it
