Thought I'd throw this one out there to see if anyone can shed any light.
The ABS & Tracs lights are on. So far I've -
Cleaned and tested the front sensors (both reading around 1060 Ohms)
Tested the wiring from the module plug to the front left sensor plug - no breaks.
Made up a flash reader and discovered fault code "311" which was front left wheel sensor circuit.
Replaced the ABS module for a guaranteed refurbed unit.
Cleared the code and now there are no codes showing.
The lights are still on and it's doing my head in.
