Frankenhealey
Club RR Member Number: 15
May 26, 2017 11:50:15 GMT
When we bought SWMBO's trials Defender the PO's dad (PO sadly deceased) said he'd find the wheel nut key. Nearly one year later with the MOT coming up and still no joy. Does anyone recognise this type of nut and could point me in the direction of a solution that does not involve cutting the wheels off please? Cheers, Ian
May 26, 2017 11:56:20 GMT
as its a nut, I would wind another nut down the thread and weld it to the locker, use a socket on the nut you welded to wind both off.
May 26, 2017 11:59:39 GMT
May 26, 2017 20:55:29 GMT
One for Monza Phil.....?
Failing that, Angel Autos on the A37 north of Dorchester have a huuuge tub of assorted wheel nut keys and will even supply you with a chair to sit on and another tub to sort them into.
How do I know this.....? This is how I got the wheels off my A8. Took me 25 minutes to find the right key, which compared favourably to the 90 minutes it took to chew one locking wheelnut off with a carbide burr (access very difficult!) and they are only 1/2 mile from work.....
Must say that yours look alot more open to an approach that doesn't need the right tool!
Nick
May 26, 2017 21:32:36 GMT
Spray it with penetrant and then put a good drift/pin punch at an angle in one hole and knock it round with a decent sized hammer.
v8ian
That looks like an old Cosmic wheel nut, If you can weld a normal nut on there what would probably work, but, looking at the nut it looks pretty symmetrical, and it might be easy enough to make a key for it,
taurus
May 27, 2017 21:07:42 GMT
Reminds me of the locking ring on an angle grinder. I guess you've tried the usual grinder key on there.
Midas
Club RR Member Number: 14
May 27, 2017 22:44:06 GMT
I have a similar lock nut arrangement that was sold for bolting my Cibie Oscars onto the car back in the day. I've just checked my key and the pattern is different enough for me not to suggest sending it over to try. In your position I think I'd be welding a nut onto it or breaking out the lathe and rotary table to make a key. As you'll be chucking them, the welded nut would be my choice.
Last Edit: May 27, 2017 22:46:48 GMT by Midas
Get it roasting hot with a blowtorch and then use a chisel and hammer to loosen it and undo it off.
BT
May 28, 2017 14:32:59 GMT
The my out of that locker is perfect for an "Irwin bolt extractor".
Seriously. I bought one a few years ago and I am super impressed with how good it is.
If you're in Kent come and borrow it. I'd go as far as guaranteeing it will work. Very simple. Very quick.
May 28, 2017 14:37:44 GMT
I think you guys are forgetting the vehicle and therefore the size of these things, the largest Irwin nutgrip is 19mm, landrover wheelnut is 27mm on a 16mm thread.
barty
May 28, 2017 17:09:13 GMT
why not pop in to a tyre specialist, they get this problem every day and I'm sure they can help out. They probably wont charge much. Thats assuming you can get the car there
May 28, 2017 17:51:05 GMT
I'd try a plumbers wrench first Second try to grind some flats on it to get a spanner on it Third weld a spare 1/2" socket to it Last, cut down the thread with a thin cutting disc
Cheers Martin
No matter how clever you think you are, stupidity is always one step ahead of you
BT
May 28, 2017 18:27:13 GMT
I think you guys are forgetting the vehicle and therefore the size of these things, the largest Irwin nutgrip is 19mm, landrover wheelnut is 27mm on a 16mm thread. I have never dealt with land rover so that's something I'd have no idea about. Welcome for raising that point. In which case my input is invalid. Edit As strange as it seems, would a grinder spanner unlock it?
Last Edit: May 28, 2017 18:28:26 GMT by BT
bstardchild
Club RR Member Number: 71
May 29, 2017 16:48:15 GMT
When we bought SWMBO's trials Defender the PO's dad (PO sadly deceased) said he'd find the wheel nut key. Nearly one year later with the MOT coming up and still no joy. Does anyone recognise this type of nut and could point me in the direction of a solution that does not involve cutting the wheels off please? Cheers, Ian Why is the stud so short compared to the one with the normal lug nut on it? Is is a wheel bolt rather than a lug nut on a threaded stud?
slater
Club RR Member Number: 78
I think you guys are forgetting the vehicle and therefore the size of these things, the largest Irwin nutgrip is 19mm, landrover wheelnut is 27mm on a 16mm thread. Well that's not true. You can get them up to at least 36mm. I wouldn't bother because quite frankly this is a 5mins job with a chisel or welded nut and extractors aren't cheap but still. ;-)
May 30, 2017 11:28:41 GMT
got a link to them? biggest I can find is 19mm.
slater
May 30, 2017 13:49:10 GMT
May 30, 2017 18:13:55 GMT
You might get a key from paddock land rover spares, I have the same set on my series 3, I'm sure mine came from them. Had a look and a generic grinder key fits the pin holes, might get u somewhere. I have a key but am located in Aberdoomshire. Pins on the key are 24mm apart on the inside edge and 35mm on outside and 5mm dia.
Last Edit: May 30, 2017 18:24:45 GMT by Gusman_2286: added photo's
njw
May 30, 2017 18:27:58 GMT
Reminds me of the locking ring on an angle grinder. I guess you've tried the usual grinder key on there. That's exactly what I thought it was when I first saw it! Personally I would give it a good douse in wd40 and then beat an old multipoint socket over it.
