Rob M
Club RR Member Number: 41
May 20, 2017 12:45:01 GMT
You have two choices. 1) Visit a forum that caters for your car and ask on there, someone will deffo know and then you can exchange the battery. 2) You pop out and get some poz and neg straps and extend what you have. Job done.
Battery terminals wrong sideBenzBoy
@benzboy
Club Retro Rides Member 7
May 20, 2017 13:15:27 GMT
I had a similar issue with my Patrol - the battery which was fitted had the terminals the wrong side, and the cables stretched over. When I came to replace it, the recommended battery was too tall to fit under the bonnet. I ended up trawling the internet for a battery with the terminals the correct side and of the right dimensions, and which had enough oomph to turn the engine over. Also I was fortunate to have a decent motor factors nearby who had lots of batteries in stock and didn't mind pulling out a few likely batteries for me to have a look at. To be fair most branches of Halfords normally have plenty of batteries in, you could take your old dead one in and compare it.
Last Edit: May 20, 2017 13:16:38 GMT by BenzBoy
Dez
Club RR Member Number: 34
Battery terminals wrong sideDez
@dez
Club Retro Rides Member 34
May 20, 2017 13:27:30 GMT
I use Tayna, www.tayna.co.uk. They list all batteries by model number as well as application, and have all the dimensions and terminal orientations/sizes listed as well as the specs. They're delivered next day and are as cheap if not cheaper than anyone else. Really couldn't be easier. A lot of Jdm cars use a different spec battery to UK spec models of the same car, u found this with my Eunos. The battery everywhere local was trying to sell me was physically too big to go In the battery tray, so I just bought one with the same cca/ah but the right size from Tayna.
eternaloptimist
May 20, 2017 14:56:14 GMT
Another vote for Tayna here. .
May 20, 2017 19:45:12 GMT
Whatever battery it is there will be one the same size with the terminals the other way around. What make and number is the battery?
May 20, 2017 20:50:32 GMT
Ignore the chart. Go to the shop and find the biggest, gruntiest size battery that will fit in the battery cradle, then make sure the one you buy has the terminals on the correct side.
Ryannn
May 21, 2017 15:53:08 GMT
I only ever buy batteries using the code for this very reason. Once you know the type you want, most have the terminal layout on the listing.
Much quicker when you own two imports!
May 21, 2017 21:13:12 GMT
That's all very well if your car is new enough to be listed on the chart. Many of us have old cars.
Battery terminals wrong sideChasR
@chasr
Club Retro Rides Member 170
I had a similar issue with my Patrol - the battery which was fitted had the terminals the wrong side, and the cables stretched over. When I came to replace it, the recommended battery was too tall to fit under the bonnet. This can be a brand problem. On my Alfa the Unipart battery was too tall to take a clamp. I've noticed this on the E36 where the height is critical for getting the top cover/keeping your stuff in the boot literally nowhere near the battery. The Halfords and Bosch items however were fine. All 3 batteries were the same size 'no'.
