Dose anyone know where I can get my hub pcd changed in or near south Yorkshire
I've changed my capri axle to a volvo axle so need to change from 5x108 to 4x108
Thanks
mk2 ford orion mk2 cavalier sri mk3 cavalier sri 95 clio 16v mk3 cavalier gsi ford scorpio mk3 cavalier tdi nissan 200sx (s13) mk3 ford transit mk2 astra gte rep mk3 3.0 v6 cavalier mk3 fiesta van mk3 capri 1.6 mk3 3.0s capri mk2 polo bready 96 bmw 3.2 evo audi 80 tdi landrover 200 tdi mk3 g40 polovan mk1 facelift vauxhall carlton estate ford sierra vw polo 6n
Where are you? LOADS of engineering shops in sheffield, most will probably do it for you.
Small possibility I could do it but would needs pics of the parts that need drilling to know if my machines will do it.
fad
I know a real good machinist in Sheffield, he's called Mel, has a unit on Garter St, Sheffield S4 7QX. Don't have a number for him mind you. But there's a little collection of units opposite the rock climbing place there on the right as you go up the hill, turn in immediately after the cafe. His unit is on the end on the right. He'll turn some up for you, he's done a few bits for me. Tell him Dave (the guy with the daft Beetle, John's mate) sent you.
hario
S202 C300STD
May 11, 2017 14:05:15 GMT
The tool for that is called a dividing head, even a small machinist is likely to have one
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
May 11, 2017 16:12:08 GMT
Where are you? LOADS of engineering shops in sheffield, most will probably do it for you. Small possibility I could do it but would needs pics of the parts that need drilling to know if my machines will do it. Hi I'm in Barnsley top side so not far from sheffield
May 11, 2017 16:12:53 GMT
I know a real good machinist in Sheffield, he's called Mel, has a unit on Garter St, Sheffield S4 7QX. Don't have a number for him mind you. But there's a little collection of units opposite the rock climbing place there on the right as you go up the hill, turn in immediately after the cafe. His unit is on the end on the right. He'll turn some up for you, he's done a few bits for me. Tell him Dave (the guy with the daft Beetle, John's mate) sent you. Lol I will I'll check him out thanks for address
