matty2300
Red ones go faster!
Dec 19, 2019 17:07:43 GMT
Its silicone free and therefore is a far more durable & readily paintable product - MS sealer is polymer based "polymer" is a descriptive term that just means long repeating chain molecule. To say that something is "polymer based" is a bit of a misnomer, polymers are all based on something - yes there are plenty of polymers that are not silicone based (Nylon, polystyrene or even your own DNA for example) but just because something is described as a polymer does not mean that it does not contain or is not based on silicone. MS polymer when regarding sealants and adhesives does stand for "modified silicone polymer"
Last Edit: Dec 19, 2019 17:40:54 GMT by matty2300
2002 Saab 93 - Daily 1972 Vauxhall Firenza Sport SL - in storage 1978 Vauxhall Magnum - PROJECT 1993 Vauxhall Cavalier 2.0 GLS - DEAD 1994 Vauxhall Astra 1.4 LS - DEAD 1999 Saab 93 2.0 SE - DEAD 1999 Mercedes W202/C200 - DEAD
Body & Paint Threadglenanderson
@glenanderson
Club Retro Rides Member 64
Dec 27, 2019 22:48:21 GMT
I actually have a proper question to ask, much to my surprise, as I’m no bodywork man.
I’m in the process of fettling a replacement roof panel for my Land-Rover. It’s apparent that several of the rivets securing the aluminium section to the galvanised steel perimeter frame have let go, and there’s ample indication that a previous owner has attempted a cure with a couple of tubes of bath sealant. I’ve got all the tooling and the correct rivets to split the parts, clean the joint and re-rivet them back together. My question would be what to use between them to ensure a weathertight seal? Something like TigerSeal? I’m not going to need to be able to paint the join, it’ll be completely hidden once the roof is refitted unless a 7’ tall man is walking past.
Dec 27, 2019 23:20:36 GMT
I actually have a proper question to ask, much to my surprise, as I’m no bodywork man. I’m in the process of fettling a replacement roof panel for my Land-Rover. It’s apparent that several of the rivets securing the aluminium section to the galvanised steel perimeter frame have let go, and there’s ample indication that a previous owner has attempted a cure with a couple of tubes of bath sealant. I’ve got all the tooling and the correct rivets to split the parts, clean the joint and re-rivet them back together. My question would be what to use between them to ensure a weathertight seal? Something like TigerSeal? I’m not going to need to be able to paint the join, it’ll be completely hidden once the roof is refitted unless a 7’ tall man is walking past. Glen - Personally I would use a proper body caulking that is flexible / moves with the panels and that can should the need ever arise be separated - using a PU sealant will make this hard work - 3M do a high quality one 08568 which I use all the time - a pack maybe more than what you currently need but you have a large Austin shaped object that this will be very useful upon (body panels / floor panels / frames etc) - the body caulking can be easily shaped / reduced & cleanly tooled - link to a E Bay seller below but you may find it a little cheaper at a local automotive refinishing factors whom stock 3M products www.ebay.co.uk/itm/3M-08568-Body-Caulking-Strips-6MMx300MM-Pack-60/113883903858?hash=item1a84027772:g:ZS8AAOSwanhdeAdmIf you only need a few strips to do the job and don't want to invest in a full pack PM me your address and I will put a couple in the post to you - Chris
Last Edit: Dec 27, 2019 23:23:00 GMT by Deleted
@glenanderson
Dec 27, 2019 23:35:25 GMT
Brilliant Chris, that looks just the job. I shall order a pack as I’m sure you’re right and I’ll find a use for the rest of it on/around the Austin and the Land-Rover. 👍👍👍
Dec 30, 2019 21:37:12 GMT
Flatting cellulose primer filler, should this be done wet or dry? I am concerned about it absorbing water & causing micro blistering later.
Dec 30, 2019 22:25:49 GMT
I've always done it dry for the reasons you state, I believe pro's use the paint oven to dry them out after flatting.
Dec 31, 2019 14:52:35 GMT
In my opinion no water should go near the bodywork until a gloss coat is applied to seal it.
Dec 31, 2019 21:01:37 GMT
Nothing wrong with wet flatting providing you dry has you go - but proper drying - use a towel and a air line blow gun to chase the water out / dry the panel off has you complete the panel a small heater / oil filled radiator close by helps - whilst dry flatting is ok you will find it very hard work to achieve anything like the correct surface for laying on paint without imperfections in the primer showing through - many bodyshops use a combination of dry & wet flatting dependant upon the type of paint being applied - providing you are methodical with the drying process you should not have any issues - I still wet flat in my workshop on occasions and don't have problems with any adverse reactions when completed to point that I also have no issues with guaranteeing the work either
Last Edit: Dec 31, 2019 21:06:26 GMT by Deleted
Heard of them but never used them - it looks like they are catering purely for the older / historic market and therefore appear to be using premium pricing - I would compare what they offer with one of the major online retailers (2 of them listed below) of such products first to see how competitive they are www.jawel.co.uk/shop.autopaintsbrighton.co.uk/
Heard of them but never used them - it looks like they are catering purely for the older / historic market and therefore appear to be using premium pricing - I would compare what they offer with one of the major online retailers (2 of them listed below) of such products first to see how competitive they are www.jawel.co.uk/shop.autopaintsbrighton.co.uk/Prices appear similar, interesting that Jawel offer a non iso 2k, I expect that there is a down side? ?
Heard of them but never used them - it looks like they are catering purely for the older / historic market and therefore appear to be using premium pricing - I would compare what they offer with one of the major online retailers (2 of them listed below) of such products first to see how competitive they are www.jawel.co.uk/shop.autopaintsbrighton.co.uk/Prices appear similar, interesting that Jawel offer a non iso 2k, I expect that there is a down side? ? Its nothing new most 2 pack paints are now isocyanate free but its still quite harmful to use unless you are wearing the correct personal protective equipment along with the correct facilities i.e a positive feed mask & suitable air extraction of the spraying area
Its nothing new most 2 pack paints are now isocyanate free but its still quite harmful to use unless you are wearing the correct personal protective equipment along with the correct facilities i.e a positive feed mask & suitable air extraction of the spraying area Worse than Cellulose? I ask 'cos I'd like to paint mine (too stingy and I want the experience) but it's going to have to be done under a tent 'cos it won't go in the garage. Celly is looking like the best fit for my needs at the moment. I say that, safe in the knowledge that I don't know what I'm talking about.
James - Yes a lot worse that cellulose - which you will be fine with - and when the time comes I can talk you through the process should you wish
Last Edit: Jan 5, 2020 19:13:05 GMT by Deleted
James - Yes a lot worse that cellulose - which you will be fine with - and when the time comes I can talk you through the process should you wish Thanks Chris, I'll definitely take you up on that. Don't hold your breath though!
James - Yes a lot worse that cellulose - which you will be fine with - and when the time comes I can talk you through the process should you wish Thanks Chris, I'll definitely take you up on that. Don't hold your breath though! James - I wont - because if I did hold my breath I would go blue and quite possibly fall over (just stating the obvious so don't get all grumpy on me)
Hard to drink Gin whilst holding you breath too. Y'know just sayin'
interesting that Jawel offer a non iso 2k, I expect that there is a down side? ? I have read - elsewhere and a few years ago - that the biggest problem with non-ISO 2K is that it never properly hardens. I was interested because I thought it might give a better finish than celly on my project, so that puts it at least three years ago. Chap (on MIG Welding forum, I think) was trying it out and left it for months, and it failed the fingernail test after all that time. Of course, it might be better now.
Jan 15, 2020 17:16:46 GMT
I'm currently flatting hi-build. I've gone through in a few places (to the epoxy), not unexpected as the roof was a mare. Ok to spot prime and re-flat in those areas? I don't need any build up just the colour to be the same. Thanks.
Jan 15, 2020 22:45:24 GMT
yes.
