Hello, I have my Mercedes OM662 2.9 5 cylinder diesel engine for sale.
It's a complete, running unit with manual injection pump and all ancillaries, including inlet & exhaust manifolds, alternator, power steering pump, flywheel & clutch, glow plug relay and wiring, also have down pipe that can go with) It has only clocked 79,000 miles and I have the MOT history from the vehicle, a Ssangyong Musso, to go with it. Engine runs excellently, see video provided. Engine has been degreased and can be mounted on pallet for courier delivery. Engine hoist available if collecting from East Sussex. £SOLDAlso a 5 speed Mercedes manual gearbox from a 1996 W202, code 717418. Bought from a Mercedes specialist, it has been cleaned and in excellent working order. £170 £120 £100 Mercedes oil pan sump from a C270 CDI, 612 diesel, engine code 612.962, part number 6470140302. Used to switch front bowl sump to rear bowl for the 5 cylinder OM series (OM602, OM662, OM605) £SOLD
eternaloptimist
Hi - is it a turbo diesel?
Hi - is it a turbo diesel? Hi - it is NA, are you looking for a TD specifically?
OUTRUN
I have the TDI version in my Rexton. Great engines. Good luck with the sale, mate!
I need your help to get back to the year 1985.
eternaloptimist
Hi - is it a turbo diesel? Hi - it is NA, are you looking for a TD specifically? I'm thinking I might not sell my G Wagen if I can find a good turbo diesel to drop into it. However, if I found an engine I'd then need to find someone to do the swap to a good standard - I've got too much on by way of other projects at the moment and I don't have the £6-8k that the professionals want to do an engine swap on a G. Will probably end up selling it at this rate.
Hi - it is NA, are you looking for a TD specifically? I'm thinking I might not sell my G Wagen if I can find a good turbo diesel to drop into it. However, if I found an engine I'd then need to find someone to do the swap to a good standard - I've got too much on by way of other projects at the moment and I don't have the £6-8k that the professionals want to do an engine swap on a G. Will probably end up selling it at this rate. Will keep a look out for a TD Photos added
May 19, 2017 16:53:39 GMT
engine and gearbox available
Jul 24, 2017 15:13:15 GMT
engine available again
Engine sold, price drop on gearbox.
