parts need are
the clamp for the 1.3 spitfire distributor. oval shaped with two bolt holes in to bolt onto block
dash pot damper for the 1.3 engine su carb x 1
drop links for the front anti roll bar for the 1.6 vitesse
handbrake cable for the 1.6 vitesse
hoses....................all of em really for the 1.3 spitfire engine
hydraulic cylinders for the clutch and brake
extended wheel studs for the vitesse x 8 ( would consider a complete 1" spacer kit of cheap enough)
exhaust manifold 1.3 spitfire
speedo for the 1.3 spitfire gearbox
this list will be added to.................
