Mar 14, 2017 21:10:31 GMT
Need to fit an exhaust at the weekend (middle section and back box), I thought the middle section would come with some slits (as the catalogue picture suggests,see below) and id simply slide it on and clamp it up using a U Clamp, however it is just a straight pipe. Do I need to cut some slits myself? And is the U clamp the best method?
Mar 14, 2017 21:20:33 GMT
Also is it worth getting some high temp paint on the bare welds?
fad
Whats on the one you took off?
fad
Mar 14, 2017 21:21:32 GMT
And no. High temp pain has tiny cracks in it to allow expansion. It will rust most likely.
Last Edit: Mar 14, 2017 21:23:53 GMT by fad
Mar 14, 2017 21:21:37 GMT
Whats on the one you took off? The cat and middle are one piece (original system), so I'm cutting the exhaust off just behind the cat.
fad
Mar 14, 2017 21:23:01 GMT
Really? That is a surprise. A downpipe, cat and middle box all in one? What car?
Mar 14, 2017 21:26:16 GMT
Really? That is a surprise. A downpipe, cat and middle box all in one? What car? Toyota Yaris Pic from ebay:
Last Edit: Mar 14, 2017 21:29:10 GMT by mgbizzle
fad
Mar 14, 2017 21:32:16 GMT
Hmm lookimg at google pics seems it is thst way.
You will need a collar that is slightly bigger diameter with slits to connect the two pieces.
'76' Datsun 260z 2+2 UK RHD.... owned since '95' none of that rust free LHD import shenanigans!
Mar 15, 2017 16:57:26 GMT
Get yourself some of these gizmos. Especially if you ever see yourself removing the pipes in the future. You can specify them with a single diameter for butt-joints or a dual diameter for slip joints. Most are stainless.
Mar 15, 2017 19:56:39 GMT
Measure external diameter - but some digital calipers from Aldi, they're so useful. Go to motor factors and buy a sleeve, they have all sizes.
Mar 15, 2017 21:16:08 GMT
the car OD is 45mm, the new exhaust has an ID of 50mm (OD of 53mm). Most of the sleeves I can see online wont have enough give in them to fit?
I doubt the exhaust will ever be removed again the life of the car, certainly not in my ownership.
Last Edit: Mar 15, 2017 21:17:33 GMT by mgbizzle
fad
Weld it then if you take the whole thing off.
