gezzard
Club RR Member Number: 69
Mar 12, 2017 20:59:10 GMT
Not car related, but it is retro. After sorting through my late grandfathers sheds barns etc I found a 1978 'S' Puch Maxi S, I've check the DVLA and it's been in the barn since 1983, and is wearing a tax disc from that year. Now I'm having trrouble starting it, apparently they can be ridden as a cycle and then started with the start lever, but this one when pedalling nothing happens, no forward movement, just the pedals spinning, am I doing something wrong? I'm expecting to be able to ride it like a pushbike! I think the procedure to get it going is this: fuel on, choke in, prime the carb until fuel drips out, hold the start lever in and pedal? but no joy. Any ideas? I'm not sure wether to keep it and tidy it up or just whack it on eBay
hario
S202 C300STD
Mar 13, 2017 11:35:22 GMT
Rebuild the carb, it's made of about 5 pieces, flush the tank, fresh fuel, check/gap/replace the plug, is there spark? what colour? Check/gap/replace the points. If the spark is still missing or weak you'll need a new coil because they fall to pieces with age.
Probably very easy and cheap to source though, I think you'd need a 2 or 3 pronged flywheel puller to replace it though.
I seem to remember the pedals where actuated by some kind of clutch/cable pull / possibly throttle position related? as they are only needed at very low speed (to start)..
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
andyborris
Mar 16, 2017 20:00:11 GMT
Girlfiend, who used to ride one back in the 70's, says "just pedal it and turn the key and off you go"!
Perhaps the 1983 petrol isn't as fresh as it could be, is it for sale by any chance, make a great birthday present for her.....
Mar 16, 2017 21:56:58 GMT
Small handle on the underside on the left side handlebar needs to be pulled when starting.
Running alongside with the puch and pulling the handle should also start it.
I could start my old one with a long belt that i wound around the flywheel and pulled...
fad
Mar 16, 2017 21:59:01 GMT
gezzard
Mar 17, 2017 19:22:35 GMT
I tried holding the lever in and running alongside, it sounds like it wants to start but doesn't. As it's been sat for so long strippping it down and rebuilding it might be the best option. Mind you, at 40 years old, 14 stone and 6'1" I might look a bit of a pillock riding it. Sadly I was making crazy frog noises whilst sitting on it the other day
Peddle and pop. Peddle it turn the key and pop away you go.
1973 MK1 2600 Capri - Located in Texas 1976 3.0S Capri - X-Pack long term Project 1978 2.0S Capri 1984 Transit County MK2 4x4 LWB 2.5DI 1985 2.8i Special Capri (v8 5.0L) 1986 2.8i Special Capri 1987 280 Turbo Technics Capri 1993 1.8TD P100 - Beater, parts collector 2008 BMW 320i Touring - Daily
Mar 24, 2017 10:51:58 GMT
www.puchshop.de/en/Saw some where that you can still get all the bits for these from Germany or Austria
Mar 26, 2017 21:47:10 GMT
Try the mobilette forum very help full bunch
It will come in handy even if you never use it
tigr
Kinda New
Thank you for this. I also have one, I tried to start it a couple of years ago but had no idea how to! I might even try again this weekend. Mine is a Daimler Puch, is it a posher version?
put it on centre stand. pull up that clutch handle (left handlebar) and pedal like mad. i'd be amazed if that thing still sparks. good luck!
gezzard
Mines in storage at the mo, but I'm going to order a new plug for it and try again.
