A mate of mine is doing a custom Capri project with x-pack bodykit among other thing..
He is going to use Sierra struts to get better angles of the front suspension while get it low enough, as you know the Sierra use the normal old Ford PCD 4X108.
His rear axle is going to be a 1041 Volvo rear axle with LSD, this has a PCD of 5x108 as most Volvo's and modern Fords.
Now the hard bit..
Is there a Sierra front hub with 5x108 pcd out on the market or is there 740 half shafts with 4x108 PCD out there?
Same wheel PCD front and back would make it so easier to get hold of wheels..
Appreciate all help guys
Richard
Now the hard bit..
Richard
