Ifor Williams CT167G twin axle, Tilt Bed trailer for sale (please let me know if you need further pics or information - I'm a dinosaur & on the limit at email )
[img src="i346.photobucket.com/albums/p410/euanmcgilp/Ifor%20Williams%20CT167G/20170222_100438_1487803141669_resized_zpsweiibn0g.jpg" src="" alt=" "]
[img src="i346.photobucket.com/albums/p410/euanmcgilp/Ifor%20Williams%20CT167G/20170222_100533_1487803127837_resized_zpsgrkwvcr4.jpg" src="" alt=" "]
[img src="i346.photobucket.com/albums/p410/euanmcgilp/Ifor%20Williams%20CT167G/20170222_100519_1487803132972_resized_zpsiw81zney.jpg" src="" alt=" "]
3500Kg Max weight, 2700Kg load capacity. All galvanising is in good condition.
Bed length 16’ (4.876m); bed width is a full 7’ (2.1336m). Will fit most vehicles on top only 22 degree ramp angle when tilted so will fit lowered vehicles.
Front toe board with cut-out / mounting for winch cable and short drop loading ramp on rear. Marker lights on front & sides all work as do the rear lights. Hydraulic hand pump for twin ram lift system – all works fine, hoses & seals on rams all good. Currently has electric winch (purchased last June). Hand winch also available (depending on purchaser’s preference).
Full dealer service last year including new tyres / brake cables / full brake overhaul. Less than 1000 miles since tyres replaced. Everything works as it should; all tie down points and strap loops work as expected (including centre-deck loops). All in all, this trailer is in very good used, but not abused condition.
The trailer is fully registered on the National Trailer & Equipment Register (https://www.ter-europe.org/) as well as directly with Ifor Williams (this will all be changed legally for new owner). It is also security marked and is Smartwater coded on all panels as well as the chassis in random areas.
£2450 ono - with electric winch.
£2150 ono - with hand winch.
Regards,
Euan 07956 972005
Regards,
Euan 07956 972005
