Postage £3 for smaller things and £8 for courier. Collection from Rotherham
Ultimate top engine steady with new poly bushes - £10.
Pressed rocker covers - £5 each
Large water pump pulley - £3
Wide damped crank pulley - £10
HS4 cone filter - £5
HS4 Carb, back plate and alu spacer - £20
2 piece radiator shroud/cowling - £10
1275 Top Hose - £3
Radiator fans - £5 each
Gearbox/engine mount - £10
Large poly bush set - £8
New CV boot kit- £4
Radiators - £10 each or £25 for all three
998 radiator brackets - £4 each
1275 radiator bracket (chromed) - £5
998 Pushrods. £10
Top Engine Steady Repair Bracket - £5
Short 998 engine. Turns freely, otherwise condition unknown. Bores look OK and wood suit the new pistons with a light hone. £40 - Collection only from Rotherham.
Complete used Pre-verto flywheel - £10 + £8 P&P
2" Centre Exit Exhaust - £30
2 x Used LCB downpipe, in good condition. - £15 each
[/url]
Silicon bottom hose with no heater take off. Waited ages for it to be made, only to find that they stuck two 90 degree bends together. Won't clear my gaycharger so no use to me. SHould fit a n/a mini fine. £10
3/4 UNF threaded inserts and bushes. Originally bough for a custom subframe build to use to bolt the tower bolts into. £10
Switch Panel - Good Condition, but dusty. £3 + £2 P&P
Ash Tray - £3 + £3.50 P&P
Rubber quick release catches £5 + £3.50 p&P
New Winged Grill Badge - £5 plus £2 p&P
Chrome Wheel Arch Covers. Good COndition, but need polishing up to look there best - £10 plus £8 P&P
Air Filter Box - £5 plus £4.50 P&P - I have several of these.
1275 Top Hose - £3
New CV boot kit- £4
998 Pushrods. £10
[/url]
