Dec 18, 2016 19:33:21 GMT
Hello guys right I got a question, I want to give me golf a xenon look, but don't want to be adding xenon kits because it may be a itch I only want to scratch for a little while, I have added a new wiring loom from the battery so I get the full power, for my lights as many may know these old vw have bad lights, now I have seen 2 lights that give that xenon look
1. Osram cool blue intense
2. Philips xenon blue vision ultra
Has anyone had any experience with these and which is better thanks
Rich
Club RR Member Number: 160
which look more like xenonsRich
@foxmcintyre
Club Retro Rides Member 160
Dec 18, 2016 21:10:55 GMT
No idea but 'blue' halogen bulbs or even filament bulbs with xenon in tend to give a worse light output than a decent 'natural' bulb I have found from experience. For the cost of a CANBUS safe HID kit I'd say if you want the look and a useable light output, just buy HIDs. I had 5000k 35w 'h7's in my Hyundai (admittedly had projector lamps) and they were ace. Looked massively OE. Any Brighter (wattage) or bluer (higher kelvin number) and it starts to look a bit pap but that's my opinion.
Dec 18, 2016 21:49:34 GMT
I see, are they easy to install or is there lots of wiring or stuff thanks
Rich
@foxmcintyre
Almost all kits are just plug and play into the OE loom, requiring you only to mount the ballast unit somewhere tidily. Or untidily. Choice is yours. Seen some dreadful installs, I made up brackets to hold them on the return lip on the slam panel, over the back of the headlamp but anything is possible. Tidier and more secure it is, the longer it's likely to last.
I see fair enough, are the bulbs used same as the normal h4 or h7 or is it the more expensive bulbs like d2r's, ? Sorry never used hid/xenon kits
Stick with 4300k if you're going HID. Blue lights are terrible (6000k) You won't be able to see much and when it rains you'll see less. This is why all weather bulbs are yellow. Canbus is for modern cars who's electrics complain when you have a bulb out. D2S is for Projectors and D2R is for reflectors, but they have a different base socket. You can get adapters though. Basically though, if your headlights aren't designed for them, you're going to dazzle everyone.
Last Edit: Dec 19, 2016 8:51:30 GMT by Soopahfly
Dec 19, 2016 10:17:42 GMT
which if you have a golf and are posting here it wont have projector lamps so no it'll not be very good with a hid lamp.
better off with something like a nightbreaker, avoid the 'xenon look'
Dec 19, 2016 23:24:39 GMT
Thanks guys, so best to stick to normal halogen bulbs, osram nightbreakers are good,
91dm
Dec 20, 2016 20:04:01 GMT
If you're looking for a xenon look, Philips do a 'white vision' which do look just like OEM 4300k/5000k. I would highly recommend them, also had Osram nightbreakers which are good just slightly more yellow but as people said give more light.
Dec 20, 2016 22:10:19 GMT
Thanks I might go for the Philips, what about these ebay ones that's have been coated blue are these any good.
Davey
Resident Tyre Nerd.
Dec 20, 2016 22:34:51 GMT
Thanks I might go for the Philips, what about these ebay ones that's have been coated blue are these any good. The long and short of it. No. They are 50p bulbs with a coating.
Dec 20, 2016 23:24:06 GMT
Right that's solves that one, on to the Philips white vision range, is the white vision the best one to go for or have they got better range also any other brands to recommend, i know osram nightbreakers, all suggestions appreciated
Rich
@foxmcintyre
I just use the Halfords branded ones, I think they are 'extreme brilliance' or some stupid name, no blue coating or any of that tosh and the light output is pretty nice. They last ok as well as they are fitted in a discovery with HD springs and competition dampers. They do some tinted but not fully blue ones too. It's not a bad place to go browse and see to be fair, if nothing else it'll give you and idea of what you are after. They often stock a good range of own brand, Phillips, Bosch and sometimes it here's too. Bear in mind also if the side lamp is in the same lens it's worth changing that too to an LED set or similar as that will dramatically alter the way the lights look when on.
Dec 21, 2016 19:12:47 GMT
Halfords ones are fine tbh. I never had issue in the Wife's car.
which look more like xenonsChasR
@chasr
Club Retro Rides Member 170
ECP are doing Osram Nightbreakers for around £13 at the moment as well.
